Momentum/velocity questions (very simple)
  • Thread starter Thread starter kaitamasaki
The discussion revolves around two momentum-related problems involving collisions and explosions. In the first scenario, a 2 kg rock collides with a 10 kg block, raising questions about the block's height after the impact, emphasizing the conservation of momentum. The second scenario involves two carts, where a spring explosion causes a 4 kg cart to move at 12 m/s, prompting calculations for the 2 kg cart's velocity post-explosion and the force exerted during the explosion. The calculations suggest that the 2 kg cart moves in the opposite direction with a velocity of -12 m/s, and the force of the explosion is estimated at 96 N. The discussion highlights the importance of impulse and momentum conservation in solving these physics problems.
kaitamasaki
A 10 kg block is hanging by a string. How high will it go up if a 2 kg rock going up at 60 m/s hits it and "sticks to it"? (acceleration of 9.8 m/s^2) this has to relate with momentum i think
a 2kg cart and a 4 kg cart are moving together at 4m/s velocity... a spring compressed between them expands rapidly, the front cart continuse at 12m/s in the same direction
a) velocity of 2kg cart after "explosion"
b) if explosion took 0.25s, what's the force of the explosion ( id ont know what mass to use, what acceleration to use)
c) velocity of front cart to acquire in order for second cart to remain stationary after explosion
formulas supposedly used are
F= ma (also is [mass * (change of velocity) ] / change of time )
p=mv
impulse = (F)(change of time)
thanks for any help
_________________
i tried doing them, for the carts question..
a) p=mv
p = (6)(4) 6 kg being total masss of the carts
p = 24 kgm/s
so momentum after is
24 = (4kg . 12 m/s) + (2kg . v) 4kg cart moves at 12 m/s after (its given)
-24 = 2v
v = -12 m/s
so 2kg cart moves -12 m/s after ? i don't know but its a guess
b) if explosion took 0.25s what's the force of it?
well i used the impulse = force * change of time formula..
24 kgm/s = F * 0.25
F = 24 / 0.25
F = 96 N? <--- is that correct? i don't know hope so =D
the last one i don't know because i think the 4kg needs to move really really fast in order for the 2kg cart to not move the opposite way at all.. but no clue how to do it
The 2 [kg] cart's negative velocity tells you the direction of its motion.
good job.
Impulse (\vec{F} \cdot \Delta t) is the quantity that CHANGES an object's momentum. You should get the same strength for the Force on the front car as you get on the back car (just opposite directions). Find the change of momentum for EACH car, and see for yourself.
The total momentum is 24 kgm/s, before the explosion and after the explosion ... I think you need a WEAKER explosion for the little car to not go in the opposite direction.
Your first problem has two parts : a collision (p conservation), then a rise (E conservation).
