Understanding Polarized Light Through Polaroid Sheets
In summary: So is the fraction of the intensity of the original beam that is plane polarized is 1/2 ?Yes, that is correct. So, in summary, the fraction of the intensity of the original beam that is plane polarized is 1/2 and its direction of polarization is horizontal.
planesinspace
1. *A beam of light that is a mixture of plane polarized and unpolarized light is incident on a sheet of polaroid. The trasmitted intensity varies as the sheet is rotated, having a maximum when the transmission axis is horizontal, and a minimum when it's vertical. If the maximum intensity is three times the minimum, what fraction of the intensity of the original beam is plane polarized, and what is it's direction of polarization?
I=Imax*cos^2*theta
(polarized light passing through analyzer)
Basically I have no idea with this one, except I'm pretty sure the answer to the last part is that its' direction of polarization is horizontal.
I also just guessed and played around with the fact that with an ideal polarizer the intensity of the transmitted light is half the incident unpolarized light, so I played around with:
Imin= I/2
Imax= 3*Imin
= 3*I/2
= 3/2*I
But that can't be right because its not a proper fraction..
Any help very much appreciated..
Hi planesinspace,
I think you need to keep track of what happens to the unpolarized and polarized light separately. Before the light passes through the polarizer, let [itex]I_1[/itex] be the intensity of the unpolarized light, and [itex]I_2[/itex] be the intensity of the unpolarized light. So before the light goes through the polarizer the total intensity is [itex]I_1+I_2[/itex].
When the transmitted light is at a maximum, what is the transmitted intensity? What is it when it at a minimum? How are these two related? Once you have those conditions you can figure out how the original intensities are realated.
Hi, thanks for your help.
Oh ok, well I have so far
I(total)= I1 +I2
Where I1 is polarised light, and I2 is unpolarized.
Then, when the light is at a maximum, hence, there is light that is both polarized and unpolarized, the total intensity = 3*Imin = I1 + I2
and when its minimum, only unpolarized light is getting through, hence there is no I1, and Imin = I2 / 2 (because half the transmitted intensity continues, although i read that is only for ideal polaroids, so once again I'm not sure if I is I/2 or I..)
For the unpolarized light, after it passes through a polarizer, its intensity is half what it was before. So your minimum expression [itex]I_{\rm min}[/itex] is correct.
However, you haven't taken that into accout for the maximum. At the maximum intensity, all of the polarized light's intensity passes through, but still only half of the unpolarized light's intensity.
So I have Imax= I1 + I2/2 = 3*Imin = 3/2*I2
So when determining what fraction of the total that is, that's where I get confused.
I1 + I2 = I total,
So can i say Itotal = I max, sorry for this confusion.
They want the fraction of the initial beam intensity that was plane polarized. This means they want:
[tex]\frac{I_1}{I_{\rm total}}[/tex]
You already have
[tex]I_1+I_2=I_{\rm total}[/tex]
and you also found:
[tex]I_1 +\frac{1}{2}I_2 = 3\left(\frac{1}{2}I_2\right)[/tex]
These last two can give you a numeric value for the fraction you are looking for after some algebraic cancellation. What do you get?
Ok well i got I1 = I2 , which means Itotal = t*I2 ,
I1/Itotal = I2/ 2*I2, so a half?
1. What is polarized light?
Polarized light refers to light waves that are oriented in a specific direction. This direction is known as the polarization direction, and it can be vertical, horizontal, or any other angle in between.
2. How do polaroid sheets work?
Polaroid sheets are made up of a special material that can filter out light waves that are not oriented in a specific direction. This is achieved through a process called polarization, where the molecules of the material are aligned in a specific direction to allow only light waves with the same orientation to pass through.
3. What is the purpose of using polaroid sheets?
Polaroid sheets are commonly used to reduce glare and improve visibility in various applications. They are often used in sunglasses, camera lenses, and 3D glasses to filter out unwanted light and enhance the clarity of the image.
4. Can polaroid sheets block all types of light?
No, polaroid sheets can only block light waves that are oriented in a specific direction. They cannot block all types of light, such as non-polarized light or light waves with a different polarization direction.
5. How does understanding polarized light through polaroid sheets benefit us?
Understanding polarized light through polaroid sheets allows us to manipulate and control the light waves that we encounter in various applications. This can help improve visibility, reduce eye strain, and enhance the overall quality of images and videos.
