Motion Problem: Struggling with Angle w.r.t Wall
The discussion revolves around a motion problem involving the calculation of an angle with respect to a vertical wall. Participants are exploring the relationship between velocity components and the angle of motion.
  • Participants discuss the use of trigonometric relationships, particularly the tangent function, to find the angle based on velocity components. There are questions about the correctness of methods for determining the y component of velocity and the use of kinematic equations.
The discussion is active, with participants seeking clarification on the methods to calculate the angle and the components of velocity. Some guidance has been offered regarding the use of tangent and kinematic equations, but there is no explicit consensus on the correct approach yet.
Participants are navigating the problem with some uncertainty about the initial calculations and the necessary components to apply the tangent method effectively. There is an emphasis on the need to determine the time to impact the wall and the corresponding vertical velocity.
Garen
Motion Problem!
Okay, so I got number one (6.36904) but I'm having real trouble getting the angle w.r.t the wall. At first I thought of taking the t (from
)[/URL] then multiplying it by the acceleration to get the y component of the velocity. I then thought of taking the inverse tangent of (5.5/Vy). But I am not sure if it is right. Did I do something wrong?
Yes, you do want something like tan(angle) = vx / vy. This gives you the angle between your vector and the vertical direction (the wall is vertical).
Can please be a little more specific?
You need the x and y components of the velocity and then you can use your tangent method.
That's what I was trying to do, but is my method of getting the y component of the velocity (listed above) right? Or was I supposed to use another method?
You'll have to use some kinematic equations. You need to find the time it takes to hit the wall and then the speed it will be traveling in the vertical direction due to that acceleration after that time. If you got the first part correct then you should already know both components surely?
