What factors should be considered when calculating motor size for a trolley?
  • Thread starter Thread starter fakhar
    Motor
To calculate the motor size for a trolley, it's essential to determine the forces needed to move and accelerate the trolley. This includes the force required to climb any slopes, overcome rolling resistance, and accelerate from rest to maximum speed. The rolling resistance will depend on factors like surface smoothness, tire type, and pressure, which may require measurement or estimation. Forces for climbing slopes and acceleration can be calculated based on the trolley's mass and desired acceleration. Understanding these factors will ensure the motor is appropriately sized for the trolley's operation.
fakhar
I want to build a trolley with four wheels and towed to a rope having pulley on both ends connected to a electric motor. one of the pulley will be drive and other will be idle. what will be the proper procedure to calculate the motor size for this type of problem. thanks in advance
First you will need to know the forces required to move and or accelerate the trolley. You could break the total force down into three parts...
1) Force required to climb slope if any.
2) Force required to overcome the rolling resistance (Depends on smooth or rough surface? Type of tyres, pressure etc)
3) Force required to accelerate from rest to max speed. Depends on mass and acceleration required.
Some things can be calculated (such as 1 and 3) but 2 may have to be measured or estimated.
Likes jrmichler
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
