Moving magnetized objects apart
  • Thread starter Thread starter gloo
To move a steel plate away from a magnet, it is possible to induce an electrical current in the plate to reduce its magnetic attraction. This can be achieved by using coil windings around the magnet to create a counteracting field. However, repeatedly doing this may affect the plate's magnetism based on its B-H hysteresis curve. The effectiveness of the current in reducing magnetism depends on its magnitude and the specific characteristics of the magnetic material. Ultimately, while magnets can do work on objects, they cannot be turned on and off to produce energy.
gloo
I want to move a steel object/plate away from a magnet - Here is my questions:
1. Can I induce an electrical current to a steel plate just large enough to allow me to pull the plate away without much attraction to a magnet? So I guess it would kind of being like the reverse of turning on an electromagnet?
2. If this can be done...will it result in some kind of permanent reduction of magnetism for the steel plate if done repeatedly?
I'm not certain what you are trying to do. Have you looked at magnetic chucks? They are devices that use variable air gaps to reduce the clamping between the chuck and the part being held.
For 1) the answer is yes. Just coil windings about the magnet and drive a current sufficient to null or reduce the field.
For 2) I think this depends on the B-H hysteresis curve of the magnetic material and how far along this curve the induced field goes.
I am just trying to imagine a way for magnets to do work on an object -- hoping to maybe patent something but I am not very well versed on the deep workings of how magnets work.
-- in response to your answer # 1 -- I don't want to neutralize the magnet but the steel plate that is attracted to --- I am assuming yes?
-- in response to # 2 -- does the B-H hysteresis factor a function of how large the electric current is that is used to reduce the magnetism of the plate?
Magnets do work on objects through a number of ways. There is the ##dW=F\cdot ds## mechanical work. Then there is the energy term ##\int{B\cdot H dx^3}## which is the energy stored in the magnetic field. Typically ##H(B)## is a multi-valued function so as ##B## is changed work is done heating the object in proportion to the area enclosed in the ##B##-##H## curve. If you are trying to get help on something you feel is proprietary best of luck. I likely can't help.
What exactly are you trying to do? You can't make energy by somehow turning a permanent magnet on and off. It doesn't mater if you try to use coil or some sort of moving shield to turn off the magnet.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
