Multiple problems dealing with springs and Hooke's Law
A vertical ideal spring with a spring constant of 132 N/m is analyzed with a 0.80-kg block placed on it in two scenarios. In the first case, when the block is placed gently, the spring compresses by 0.0594 meters, calculated using the weight of the block. In the second scenario, where the block is dropped, the compression involves additional kinetic energy considerations, as the force on the spring starts at 7.84 N instead of increasing from zero. The energy stored in the spring differs between the two cases, requiring an understanding of both potential and kinetic energy. The discussion emphasizes the importance of energy concepts in determining the spring's compression when the block is released.
TmrK
A vertical ideal spring is mounted on the floor and has a spring constant of 132 N/m. A 0.80-kg block is placed on the spring in two different ways. (a) In one case, the block is placed on the spring and not released until it rests stationary on the spring in its equilibrium position. Determine the amount (magnitude only) by which the spring is compressed. (b) In a second situation, the block is released from rest immediately after being placed on the spring and falls downward until it comes to a momentary halt. Determine the amount (magnitude only) by which the spring is now compressed.
Fapplied=kx
First part is solved with an answer of 0.0594m. Second part has me lost.
EDIT: Solved problem.
You have the first part with no trouble. The mass has a weight of 0.8 x 9.81 =7.84N and you have used the spring constant value correctly to calculate the extension, 0.059m.
You now need to think about ENERGY. When the weight is PLACED on the spring the force on the spring increases uniformly from 0N up to 7.84N.
(I hope that you can picture the straight line graph of F against extension)
The work done on the spring (elastic PE stored) = AVERAGE FORCE x distance.
The average force is 0.5F and so the energy stored is 0.5F x extension (area under the straight line graph?... you should be familiar with this equation)
When the weight is dropped (released) the force on the spring does not start at 0 and increase to 7.84N uniformly. It is 7.84N from the start so the PE given up by the weight is not 0.5F x ext, it is F x ext, but at this point the energy stored in the spring is only 0.5F x ext... there is some extra energy that needs accounting from... think KE
Can you take it from there?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
