Multiplication by a matrix in GL rotates a plane's basis?
joej24
Let [itex]A = (a_{ij})[/itex] be a [itex]k\times n[/itex] matrix of rank [itex]k[/itex].
The [itex]k[/itex] row vectors, [itex]a_i[/itex] are linearly independent and span a [itex]k[/itex]-dimensional plane in [itex]\mathbb{R}^n[/itex].
In "Geometry, Topology, and Physics" (Ex 5.5 about the Grassmann manifold), the author states that for a matrix [itex]g\in \textrm{GL}(k,\mathbb{R})[/itex],
[itex]\overline{A} = gA[/itex] defines the same plane as [itex]A[/itex] because [itex]g[/itex] simply rotates the basis within the [itex]k[/itex]-plane.
I'm having trouble seeing this.
Let ##r_j## denote the ##j##th row of ##A##, and consider a vector ##v## that is normal to the ##k##-dimensional plane. Note that ##v## must be perpendicular to all ##r_j##, so ##r_j\cdot n=0##.
Then ##Av=0## since the ##j##th component of ##An## is ##r_j\cdot v##.
So ##\bar Av=(gA)v=g(Av)=g\mathbf 0=\mathbf0##. So ##v## is also normal to the plane defined by ##\bar A##. Since that holds for all ##(n-k)## basis vectors of the null space of ##A##, and the rank of ##\bar A## is the same as that of ##A##, the plane (its rowspace) must be the same.
Thank you, I understand now. When you say
this means that all the ## v ## perpendicular to the ## k##-dimensional plane satisfy ## \overline{A} v = 0##.
  • · Replies 17 ·
