Multivariable Calculus - a question of limits
PhysicalProof
Prove the following, using the meaning of a limit:
epsilon > 0, delta > 0
0 < sqrt(x^2 + y^2) < delta
| f(x) - 0 | < epsilon (1)
So, I know that I have to elaborate on the inequality in (1), further. However, I'm not sure of how to go about this. If I start transposing it seems to get much too messy and I end up with a proposed delta which seems far too complex. Is there some simplification that I'm overlooking here?
Any help is really appreciated, ta.
Could you not use polar coordinates instead?
Then the equation would be much simpler and the limit is just as r goes to 0
I did consider that but I'm pretty sure the limit definition must be used here (as a requirement).
Does anyone have any ideas of how to simplify this beast?
EDIT: Really need this one clarified guys. Does anyone have any hints at all? Even a vague idea.
Hint: use the fact that |x|<r and |y|<r, where r=sqrt(x^2+y^2).
Bingo, great hint, thank you! Subtle yet it serves me well :D♦
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
