Naming question; Michael Aldol Condensation
  • Thread starter Thread starter Leakyrex1
    Condensation
The discussion centers on the proper naming of a compound synthesized through a Michael aldol condensation experiment. The original poster seeks clarification on their proposed name, which includes a 4-methyl substitution on one of the diphenyl groups. They initially suggest the name 6-ethoxycarbonyl-3-phenyl-5-(4-methylbenzyl)-2-cyclohexenone. Respondents emphasize the importance of accurate nomenclature, recommending the use of "4-methylphenyl" instead of "4-methylbenzyl" and advising against the use of "toluene" terminology in favor of "p-tolyl." They also suggest using chemical structure drawing software, such as ChemSketch, to better visualize the compound for accurate naming.
Leakyrex1
Hi everyone,
So I am performing a michael aldol condensation experiment and i was wondering if anyone can help with the naming. An example of naming would be 6-ethoxycarbonyl-3,5-diphenyl-2-cyclohexenone. This example was in my lab manual; the compound I am synthesizing, has a (p) or 4-methyl on only one of the diphenyls of the example compound. So my question is, I understand that when a benzene ring has a methyl, it is named toluene. This is how i am naming my compound: 6-ethoxycarbonyl-3-phenyl-5-(4-methylbenzyl)-2-cyclohexenone. Does this sound right? my next guess would be to -5-((p)-toluenyl)-2-cyclo... thanks for the help.
Chemistry news on Phys.org
Nobody will be able to help not seeing the compound...
Borek is right, no one will be able to help you if you cannot draw or show an image of your compound. You can use a simple free software like ChemSketch to draw your chemical structures. Check out this link to view information about the software:
http://www.acdlabs.com/resources/freeware/chemsketch/
Regards.
Leakyrex1 said:
Hi everyone,
Your first name preferred, except that it should be 4-methylphenyl and not 4-methylbenzyl, if I understand you correctly. The toluene nomenclature is less desirable (not systematic), but if used, it should be p-tolyl not p-toluenyl. Another place to get chemical structure drawing software for free is: http://www.chem.wisc.edu/areas/reich/plt/winplt.htm
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
