Is the IXTP86N20X4 MOSFET a Suitable Choice for Driving at 5V?
  • Thread starter Thread starter core7916
    Mosfet
The IXTP86N20X4 MOSFET is challenging to drive at 5V, particularly in a boost converter application. Users have struggled with switching issues, indicating that the problem may lie in the physical circuit rather than the simulation. Dedicated MOSFET drivers are recommended for effective operation, as standard amplifiers may not provide sufficient speed or stability. The discussion highlights the need for a complete schematic to diagnose issues properly and emphasizes the importance of understanding the surrounding circuit components. Overall, using a more suitable MOSFET or a logic-level option could simplify the driving process.
core7916
TL;DR Summary
How to drive mosfet.
Hello. Can any one help me to drive the mosfet - IXTP86N20X4 Mosfet. I tried with 555 timers, amplifiers(opa 404). Unable to drive the mosfet.
Is there any other way to drive. Any suggestions.
I have attached the datasheet.
That depends on what the MOSFET is driving, and how quickly it needs to switch.
There are dedicated MOSFET drivers.
Maybe if you attach one of the circuits that you have tried to your next post, we will be able to identify why it did not work, and what changes are needed.
I have directly connected amplifiers. I dont have much knowledge about this, please suggest modification.
We need more information. We need to know the voltage of the MOSFET source, relative to the input to the buffer amplifier.
Why do you need the MOSFET ?
What load is the MOSFET driving ?
How are the source and drain connected to the load ?
I am making one boost convertor. And i have already attached datasheet of mosfet.
Is the problem with a physical prototype or with a simulation of the circuit?
There is little I can do without the full schematic of the circuit.
The MOSFET is not there alone, it is intimately connected to all the other components on the schematic. How the MOSFET is driven, will be determined by the whole of the surrounding circuit.
Sir, i am using basic boost circuit to get higher voltage. The simulation is working fine. Only thing is mosfet is not switching properly.
The problem is somewhere in the physical circuit that is different to the simulation.
Please post the circuit you simulated.
300 kHz → T = 3.3 usec;
Guess at 150 nsec rise and fall times;
3 usec remains, 1.5 usec high or low;
t = 150 nsec;
c = 2200 pF;
v = 5 volt;
c = q / v = i * t / v ;
i = c * v / t ;
i = 2200p * 5 / 150n ;
i = 2.2 * 5 / 150 ;
i = 0.073 amp = 73 mA .
There should be no problem driving the gate with 75 mA .
For first look, that mosfet is not really an easy one to use. What's the drive voltage?
I suggest to get a logic level one instead, because this one is just ... well, not exactly beginner friendly.
All the critical details needed are in the schematic diagram and the simulation.
Changing the friendliness of the MOSFET will not make one iota of difference, without the support circuit. I am going to back out of this thread until a schematic diagram is produced.
You are using a (linear) op-amp, about 6MHz GBW and something like 10mA of drive capability. It may not be able to operate stably with your huge capacitive load. In any case it will be WAY TO SLOW. You need a digital circuit to drive a MOSFET gate, like one of the innumerable gate drive ICs out there, or maybe just a couple of transistors.
You say you want help and "don't know much" but... google is awash with information about driving MOSFETs. Sorry, driving a high power MOSFET like this in a boost converter will require you to study a bit. Honestly, I don't know where to start to help yet. This doesn't sound like a circuit that can be built successfully via social media posts.
In any case, you have been asked a few times to show us your schematic, or at least describe the application, and you haven't. As if, all boost converters are the same thing I guess?
So, do an internet search for "MOSFET drive circuits" also "boost converters" read something, ask us specific questions. Motivate us to help you, we are confused about what your real problem is.
Exactly. He's asking about driving an 80A, 200V MOSFET in a boost converter. It's not friendly. Also, no one uses logic level MOSFETs in high power SMPS, for many reasons, not the least of which is that you can't find any to buy.
I am uploading image of schematic. If this mosfet is able to use in boost converter. Pls suggest other mosfets.
Pls suggest any corrections also..
Sure. But, you know, by the time of the mention of 555 it could be ... guessed that we don't have an actual SMPS here, and based on the previous topic and the general approach the available input/logic voltage could be also determined fairly accurately.
At this point the only thing I can suggest here (apart from trying this again after some more study) is to try it at significantly lower frequencies and with a logic level FET. It would spare lot of trouble for the OP at these starting steps.
Where does one find polarized 390 picofarad capacitors? ;)
You don't. They are all non-polar, typically disc-ceramic construction.
Polarized capacitors are only used/made when an extremely high value (a few microfarads and up) is needed in a small space. Also their lifetime and reliability is much less than non-polar caps, and they typically are not very good for high frequency applications.
Cheers,
Tom
Cheers,
Tom
It was a rhetorical question.
Hmm... o:) But the question fit so well into the level of the thread! That's what I get for reading the post and not noticing the author.
Sorry @Averagesupernova.
Tom
Am I wrong to point out at Fig 2 shows this Mosfet is totally NOT suitable for 5V.
And the Schematic does not have a load ? So we charge a cap, and done?
You are correct.
There needs to be some form of input current limit and output voltage regulation. If the MOSFET could be reliably turned on, the voltage at the output would continue to rise until the capacitor failed due to the high voltage.
There is no specification of the maximum output current required, nor the maximum ripple voltage.
