How Do I Start Solving a Lagrangian Mechanics Problem?
  • Thread starter Thread starter bombz
    Lagrangian
bombz
http://img85.imageshack.us/gal.php?g=hw1y.jpg
Its an imageshack gallery
Book gives completely irrelevant equations.
I couldn't even solve A. I have no clue how to start this. The instructor isn't providing any assistance and it's not a book problem meaning, book equations are completely irrelevant.
Please help . I need guidance. If could solve it and then help me step by step with explanation, that would be great :) thank you!
When you say you couldn't do part A, what was your confusion? Taking the partial derivatives? Identifying Fi? It's easy to say you're completely confused, but you should try to explain what little bit that you do understand.
This problem is pretty much just grinding through some math. You're given a Lagrangian
L=\frac{1}{2}m_1\dot{x}_1^2+\frac{1}{2}m_1\dot{x}_2^2-\frac{k}{|x_1-x_2|}
and the Euler-Lagrange equations
\frac{\partial L}{\partial x_j} - \frac{d}{dt}\,\frac{\partial L}{\partial \dot{x}_j} = 0
For part (a), plug that Lagrangian you're given into the Euler-Lagrange equation. You'll end up with a term like m_j\ddot{x}_j in your result. Isolate it. What it's equal to is Fj.
Treat the coordinates and velocities as independent variables, and it will simplify things if you write the potential as
V(x_1,x_2) = \frac{k}{|x_1-x_2|} = \frac{k}{\sqrt{(x_1-x_2)^2}}
to get rid of the absolute value.
If you're getting stuck, post your work so we can see how and where you're getting stuck or going wrong.
Oh my gosh. Thank you so much! exactly what I was looking for. I worked through it so well with your help. THUMBS UP!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
