How Do You Calculate Average Velocity and Relative Air Velocity?
  • Thread starter Thread starter nando94
    Vectors Velocity
To calculate average velocity, displacement is divided by total time, but the initial example yields 3.14 m/s, which does not match the provided options. The discussion also covers determining the velocity of air with respect to the ground using vector components from a jet's velocities. Participants suggest breaking down the velocities into their x and y components for accurate calculations. There is confusion regarding the correct application of vector subtraction, emphasizing the need to align directional components properly. Clarification on vector operations is essential for solving both problems accurately.
nando94
1. A car with an initial direction of north moves clockwise one quarter a circle of radius 30 m in 15 s at a constant speed. What is the average velocity?
a) 1 m/s north
b) 1.41 m/s northeast
c) 1.57 m/s southwest
d) 2.83 m/s northeast
displacement/total time = avg velocity
15pi/15s = pi = 3.14 m/s
but none of the answer choice are 3.14 m/s. also how do you find the direction?
2. The velocity of a jet with respect to the ground is 200 m/s at an angle of 30 degrees north of east. The velocity of the jet with respect to the air is 150 m/s at an angle of 60 degrees north of east. What is the velocity of the air with respect to the ground?
a) 102 m/s 17 degrees south of east
b) 134 m/s 49 degrees south of east
c) 134 m/s at 17 degrees north of east
d) 203 m/s at 65 degrees north of east
e) 112 m/s at 50 degrees north of east
I the jets velocity into its components and got vy = 100 and vx = 173. Then with respect to the air vy = 130 vx = 75.
Then i took the sqrt of (173 - 130)^2 + (100 - 75) ^ to get 103 m/s but I think I am doing something wrong.
Velocity is a vector. It's the change in the position vector divided by the time.
What is the change in the position vector?
Yes, you're mixing up the vx's with the vy's. Try again, making sure you only take differences of speeds in the same direction.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
