Need help with velocity problems PLease
  • Thread starter Thread starter xlogit3k
    Velocity
To solve the velocity problem, the work done on the object can be calculated using the formula Work = Force x Distance, which in this case is 38N multiplied by 0.569m (56.9 cm). This work is equal to the kinetic energy (KE) of the object, allowing the equation KE = 0.5 * mass * velocity^2 to be used. By rearranging the kinetic energy formula, the velocity can be determined by solving for v in the equation v = sqrt(2 * KE / mass). It's important to clarify that all work is assumed to convert into kinetic energy without any losses.
xlogit3k
Need help with velocity problems! PLease
Work is also measured in Joules. If a 2.59 kg object moves a distance of 56.9 cm as a result of 38N of foce. How fast is the object moving.
I started by trying to find the velocity using the square root of 2K(kinetic Energy) divided by the mass.
what did you get for KE in terms of the values provided?
idk i need help with this stuff in general
The question is a bit fuzzy IMO, but it starts with a statement about work.
Work is defined as force x distance.
If we can assume that all of that work went into propelling the object and none into say potential energy like moving it up a ramp:
the kinetic energy of the mass should be equal to that same quantity.
  • · Replies 47 ·
  • · Replies 20 ·
  • · Replies 17 ·
