Need some expert help on doppler's effect
  • Thread starter Thread starter andy_un
The discussion centers on calculating the speed of a detector moving away from sound tubes while detecting frequencies. The fundamental frequency for each tube is determined using the appropriate formulas for one and two open ends. The calculations show that the detected frequency equals the fundamental frequency, leading to a consistent speed for the detector across all tubes. This is attributed to the relationship between harmonics and fundamental frequencies, which remains constant regardless of tube length or configuration. Thus, the speed of the detector is the same for all tubes at 228.67 m/s.
andy_un
There are in total 4 tubes. The 3rd harmonic is set up in each tube, and some of the sound is detected by detector D, which is moving directly away from the tubes. What is the speed of the detector if the detected frequency is equal to each tube's fundamental frequency?
Tube 1: length 1.0m, one open end
Tube 2: length 1.0m, two open end
Tube 3: length 2.0m, one open end
Tube 4: length 2.0m, two open end
speed of sound = 343 m/s
f = n*v/(4L) for one end tubes
f = n*v/(2L) for two end tubes
f = f0 [(v+/-vD)/(v+/-vS]
So i just plug in the known values into the equation, but I got the same speed of the detector for each tube. Is that supposed to be correct?
For more clarification, I will provide an example of how I calculate using data for tube 1:
f0 = n*v/(4L) = 3*(343m/s)/[4(1.0m)] = 257.25s-1
f = n*v/(4L) = 1*(343m/s)/[4(1.0m)] = 85.75s-1
f = f0 [(v-vD)/v]
85.75s-1 = 257.25s-1 * [(343m/s-vD)/343m/s]
vD = 228.67 m/s
Yes. Irrespective of the length of the tube, or whether it is open or closed, the 3rd harmonic is always 3 times the frequency of the fundamental.
So in the Doppler formula, you always have the same ratio of the two frequencies,and therefore the same speed for the detector.
