Need to find if a sequence of functions has uniform convergence
The discussion revolves around the uniform convergence of a sequence of functions defined as \( f_n(x) = \frac{nx}{1+n^2x^2} \) for \( x \in [0,1] \). The original poster is attempting to determine whether this sequence converges uniformly to the function \( f(x) = 0 \).
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the concept of uniform convergence and discuss the need to find the maximum of the sequence of functions on the interval. There are attempts to differentiate the function to locate extreme points, with some confusion about the results and their implications.
Participants are actively engaging with the problem, questioning the behavior of the functions and the implications of their findings. Some have suggested methods such as differentiation to analyze the functions, while others express uncertainty about the interpretation of their results. There is a recognition of the need to understand the maximum values of the functions in relation to uniform convergence.
There is an ongoing discussion about the behavior of the functions at specific points and the implications for uniform convergence, particularly concerning the epsilon-delta definition. Participants are also considering the effects of the interval constraints on their findings.
natasha d
f[itex]_{n}[/itex] is is a sequence of functions in R, x[itex]\in[/itex] [0,1]
is f[itex]_{n}[/itex] uniformly convergent?
f = nx/1+n[itex]^{2}[/itex]x[itex]^{2}[/itex]
uniform convergence [itex]\Leftrightarrow[/itex]
|f[itex]_{n}[/itex](x) - f(x)| < [itex]\epsilon[/itex] [itex]\forall[/itex] n>= n[itex]_{o}[/itex] [itex]\in[/itex]N
lim f[itex]_{n}[/itex] = lim nx/1+n[itex]^{2}[/itex]x[itex]^{2}[/itex] = 0 if
n→∞ n→∞ x[itex]\in[/itex] [0,1)
= lim (1/n)(1/(n[itex]^{2}[/itex]x[itex]^{2}[/itex])=1) if x=1
n→∞
=0 as we sub x=1 and then sub the limit as 1/n = 0
hence seq converges to f(x) = 0, proving pointwise convergence
for uniform convergence we'll need a n[itex]_{o}[/itex] [itex]\in[/itex]N independent of x
|f[itex]_{n}[/itex](x) - f(x)|<ε
ie |nx/(1+n[itex]^{2}[/itex]x[itex]^{2}[/itex]) - 0|<ε
cant seem to manipulate the inequalities for an n
I would suggest you try to find the maximum of [itex]f_n(x)=\frac{nx}{1+n^2 x^2}[/itex] on the interval [0,1]. Use calculus.
would that be at x = 1?
[itex]\Rightarrow[/itex] n/[itex]\epsilon[/itex](1+n[itex]^{2}[/itex])< the required n
n is variable.. i don't get it
No, no. Use calculus. We aren't to the epsilon-delta part yet. Take the derivative of f_n and set it equal to zero and try to figure out where the extreme points of the function are. The result will be informative. You want to figure out how your functions are behaving before you start thinking about the proof.
tried differentiation got x=[itex]\sqrt{1/n}[/itex] by equating it to 0
what on Earth does that mean...
anyway how do we know the extremes of each function in the sequence of
functions is defined by the same extreme. Sorry if I am being an idiot.. but i seem to be not understanding something
wait what did you mean by the way the function is behaving?
You aren't being an idiot. My only problem with that is when I differentiated I got x=1/n. How did you get x=1/sqrt(n)? Don't give up on this. The answer is actually pretty simple once you get it right. What did you get for a derivative?
I mean in the sense of being about to sketch a graph of y=f_n(x). f_n doesn't approach 0.
that was a stupid error actually
it came to something like this 1-n[itex]^{2}[/itex]x[itex]^{2}[/itex]=0
do we overlook the -ve x because of the interval [0,1]?
Yes, ignore the negative root. So what's the max of f_n and where does it occur?
now I am lost completely
do you mean f is maximum at some x? for every n?
No, a different x for every n. The max is at x=1/n. What's f_n(1/n)?
is it .. half?
your probably like this right nowhttp://fastfoodies.org/wp-content/uploads/Head-desk-1.jpg
natasha d said:
is it .. half?
Yes, f_n(1/n)=1/2. I actually hadn't gotten to that point, but thanks. I knew you'd see it. So you see why that makes a problem for uniform continuity?
does this have something to do with the for every ε part?
ie the diff between f[itex]_{n}[/itex](x) = 1/2 and f(1/n) = 0 is greater than some ε (ie ε < 1/2)
i think I've got it
Thank you Dick
  • · Replies 18 ·
  • · Replies 34 ·
