How can negative potential difference be achieved in an electric circuit?
Negative potential difference in an electric circuit can be achieved by referencing measurements to different terminals of a battery. When the negative terminal is connected to ground potential, voltages measured at various points will appear positive. Conversely, if the positive terminal is used as the reference point, the voltages will read negative. This concept parallels gravitational potential, where moving upwards increases potential and moving downwards decreases it. Understanding this principle is essential for accurately interpreting voltage measurements in circuits.
paulojomaje
I've heard about this over and over again, but i don't how this(negative pd) can be achieved in an electric circuit.
It's a potential difference in the opposite direction of a positive one.
If you go Upstairs, you are increasing your gravitational potential with respect to where you started off. If you go Downstairs, then your potential is decreasing. In the same way, connecting a battery with its negative terminal at 'ground potential' (the black wire on your meter, perhaps), then your meter will show positive voltages at different places in your circuit.
If you connect the black wire of your meter to the positive terminal then the voltages you measure will all read negative - because you are measuring the potential relative to a higher value.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
