Calculating the Net Force Vector for Multiple Force Vectors
The discussion focuses on calculating the net force vector from three given force vectors, F1, F2, and F3, with specified magnitudes and directions. The initial calculations for the x and y components of each vector were shared, but there was confusion regarding the angle used for F2, which was incorrectly stated as 130° instead of -140°. Participants suggested verifying the calculations by drawing the vectors and checking each step for accuracy. The correct resultant for the x and y components was emphasized as crucial for determining the overall net force vector. Accurate calculations are essential to arrive at the correct magnitude of the net force vector.
bigzee20
Consider 3 force vectors F1, F2, and F3. The vector F1 has magnitude F1 = 36N and direction θ = 110°; the vector F2 has magnitude F2 = 22N and direction θ = - 140°; and the vector F3 has magnitude F3 = 28N and direction θ = 20°. All the direction angles θ are measured from the positive x axis: counter-clockwise for θ > 0 and clockwise for θ < 0.
What is the magnitude F or the net force vector F = F1+F2+F3? Answer in units of N.
I found the x resultants to be -12.31 + -14.14 + 26.31 = -0.14
I found the y resultants to be 33.83 + 16.85 + 9.58 = 60.26
(sqrt)-0.14^2 + 60.26^2 = 60.26
Can someone tell me were Iam going wrong?
Can you show us detail about how you derived the x- and y- components for each vector?
I think you have switched x and y components on one of your vectors, and have a sign wrong. I think it's best to draw each vector separately and write out all the steps -- that way you can check if these intermediate parts are correct.
ok here is what i did
F1x = 36N cos110 = -12.31
F1y = 36N sin110 = 33.83
F2x = 22N cos130 = -14.14
F2y = 22N sin130 = 16.85
F3x = 28N cos20 = 26.31
F3y = 28N sin20 = 9.58
then i found the resultant for the x and y component
Check your vector 2... why do you have 130 degrees?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
