25N Sideways Force on 10kg Box: F = m*a Formula Error
A 25N sideways force is applied to a 10kg box moving at a constant speed of 5 m/s. The discussion clarifies that if the box is moving with constant velocity, the net force acting on it is zero, indicating no acceleration. The presence of friction was questioned but not confirmed, suggesting it may not be a factor. The hint provided encourages careful consideration before applying equations. Ultimately, the conclusion is that the net force is zero due to the absence of acceleration.
mystry4
If you have a 25N sideways force on a 10kg box that moves at speed of 5 m/s, what is the formula? I used F = m*a and got it wrong. :confused:
What are you being asked to find out?
I am being asked to find the net force on the box.
well, so far the only force acting on it is the 25 N,
Is there friction?
Also, if the box is moving with constant velocity, i.e. no acceleration, then the net force is zero.
Well that makes sense...and probably why a HINT was put in there (HINT: Think about this a bit before writing down any equations!)
So, I amanswering that the net force is O because of continual velocity and no acceleration.
Thank you for your help
