Calculating Net Work: A Box Being Pushed Across a Floor
The net work done on the box is calculated by first determining the net force acting on it, which is 52 N to the right after accounting for the friction force. Using the formula for work, W(net) = Fd cos(theta), with a displacement of 8 meters and an angle of 0 degrees, the calculation yields 416 joules. The solution appears correct based on the provided values and equations. This confirms that the net work done on the box is indeed 416 joules.
subopolois
a box is pushed horizontally across a floor with a force of 70 N to the right. There is a friction force also acting on the box in the opposite direction of 18 N. if the box is displaced 8 meters. what is the net work done on the box?
W(net)= Fd cos (theta)
the net forces on the box in the horizontal direction is= 70N - 18N= 52N to the right
Since its moving horizontally, which is 0 degrees. and I am given displacement as 8 meters, and the force calculated above:
w(net)= (52N)(8m) cos (0)
= 416 joules
Does this look right?
Yeah its look like right
