Newtons law question (Baseketball player)
To determine the constant force a 70.0 kg basketball player must exert against the ground to achieve a vertical jump of 0.80m, the player must first crouch 0.20m before jumping. The initial calculations involved finding the necessary velocity and acceleration using the kinematic equation, leading to a velocity of 3.95 m/s. The correct approach requires using the crouching distance (0.20m) to calculate acceleration, resulting in an acceleration of 39 m/s². Applying Newton's second law, the total force exerted by the player is calculated to be 3400N, correcting earlier miscalculations. Understanding that upward acceleration only occurs while the player is in contact with the ground clarifies the role of the crouch in the jump.
lovemake1
Question reads: An exceptional vertical jump from rest would raise a person 0.80m off the ground. to do this what constant force would a 70.0 kg person have to exert againts the ground. Assume the person lowers himself by 0.20m prior to jumping and remains in a standing position while in the air.
My progress: well firstly i drew a free body diagram of him on the floor. (Fn[up] and Fg[Down]) and when he is in the air (Fg[Down])
then i tried finding out the velocity and hopefully i can find acceleration afterwards.
i used vf^2 = vi^2 + 2ad
i set accelration as (-9.8m/s^2) because once he is in the air gravitational force pulls him down.
am i going in the wrong direction ? where should i begin this problem. I am also confused why crouching 0.20m prior to jumping would change anything.
please further guide me with this problem. thanks.
You have 2 problems to deal with, first is a freefall problem to find what velocity you need to give the required height. Then you need to find the acceleration required to give you that velocity.
ok, now i understand that you can use the same equation to find the velocity and acceleration by plotting the numbers correctly.
so i found the velocity by using equation vf^2 = vi^2 + 2ad
vf^2 = 0 +2(-9.8)0.8
vf = 3.95m/s
(but question said he crouched 0.2m where does this go ??)using this velocity i sub it back in 3.95 = 0 + 1.6a
a = 2.46m/s^2
with this acceleration i use Newton's 2nd law
Fnet = ma
Fapp - Fg = ma
Fapp = ma +Fg
Fapp = 70(2.46) + 70(9.8)
fapp = 858.2N
But wait,The answer sheet says it should be 3400N or 340N (my teacher writing is messy)
what did i possibly do wrong here?
vf = 3.95m/s
This looks good to here
a = 2.46m/s^2
Where did this come from, please show us.
Here is where you need to use the .2m crouch. You have a zero inital velocity and the final velocity you have found above. You need to find the acceleration which works with these values.
Fnet = ma
Fapp - Fg = ma
Fapp = ma +Fg
fapp = 858.2N
what did i possibly do wrong here?[/QUOTE]
ah ha... there was my problem.
corrected answer: Vf^2 = vi^2 + 2ad
3.95^2 = 0 + 2a(0.2)
15.6025 = 0.4a
a= 39m/s^2Fnet = ma
fapp - mg = ma
fapp = ma + mg
fapp = 2730 + 686
fapp = 3400N
i made a mistake using 0.8m for the distance rather than 0.2m
but I am not sure why this is the case. he achieved the velocity of 3.95m/s during his flight.
not just in a mere distance of 0.2m ? can you clarify this concept more clear?
When jumping you can only accelerate upwards as long as your feet are on the floor. As soon as your feet leave the floor, gravity takes over and you now accelerate at g.
As soon as your legs are straight your feet leave the floor. That occurs at .2m.
great, thanks for your help :D
  • · Replies 38 ·
  • · Replies 28 ·
