Solving Force & Mass Ratios: Find m1/m2 & Acceleration
In summary, when a force F is applied to two objects with masses m1 and m2, producing accelerations of 3.0 m/s2 and 1.0 m/s2 respectively, the ratio of m1/m2 is 0.333. When m1 and m2 are combined, the acceleration of the combined mass (m1+m2) under the same force F is 0.75 m/s2.
bumblebeeliz
38
A force F applied to a mass m1 produces an acceleration of 3.0 m/s2. The same
force applied to a second object of mass m2 produces an acceleration of 1.0
m/s2.
a. Find the value of the ratio m1 / m2.
b. If m1and m2 are combined, what will be the acceleration of the combined mass (m1+ m2) under the action of the force F?
F=ma
a)
I didn't know where to begin. So I chose a random number and assumed that my force was 6 N.
6N = m1 a1
6N = m1 (3.0 m/s2)
6N / 3.0 m/s2 = m1
2 kg = m1
6N = m2 a2
6N = m1 (1.0 m/s2)
6N / 1.0 m/s2 = m2
6 kg = m2
m1/m2 = 2kg/6kg = 0.333 = 3 x 10 -1
b)
F = (m1+m2) a
6N = (2kg + 6kg) a
6N / 8kg = a
0.75 m/s2 = a
Any suggestions? :)
bumblebeeliz said:
a)
6N = m1 a1
6N = m1 (3.0 m/s2)
6N / 3.0 m/s2 = m1
2 kg = m1
6N = m2 a2
6N = m1 (1.0 m/s2)
6N / 1.0 m/s2 = m2
6 kg = m2
While this is correct. You didn't need to say F=6. It said the it applied the same force so F1=F2
or simply put m1a1=m2a2
bumblebeeliz said:
b)
F = (m1+m2) a
6N = (2kg + 6kg) a
6N / 8kg = a
0.75 m/s2 = a
Any suggestions? :)
So if F is the same, either F=m1a1 or F=m2a2
So you want F=(m1+m2)a . So you can put F equal to which either one you want and solve from there.
Makes more sense! Thanks :)
Related to Solving Force & Mass Ratios: Find m1/m2 & Acceleration
1. What is the equation for solving force and mass ratios?
The equation for solving force and mass ratios is F = m1a1 = m2a2, where F is the force applied, m1 and m2 are the masses of the objects, and a1 and a2 are the corresponding accelerations.
2. How do I find the mass ratio (m1/m2) in a force and mass ratio problem?
To find the mass ratio, divide the mass of one object by the mass of the other. For example, if m1 = 5 kg and m2 = 10 kg, then the mass ratio would be 5/10 = 0.5.
3. What does the acceleration represent in a force and mass ratio problem?
The acceleration represents the rate of change of an object's velocity due to the applied force. It is measured in meters per second squared (m/s^2).
4. Can I use the same equation to solve for acceleration if the masses are known?
Yes, you can use the same equation to solve for acceleration if the masses are known. Rearrange the equation to solve for a1 or a2, depending on which acceleration you are trying to find.
5. How do I know if my solution for the force and mass ratio problem is correct?
You can check the validity of your solution by plugging in the values for the force, mass, and acceleration into the original equation. The left side of the equation should be equal to the right side, confirming that your solution is correct.
