How many bright rings are produced in Newton's Rings experiment?
  • Thread starter Thread starter threewingedfury
    Fringes Rings
In the discussion about Newton's Rings, participants analyze the number of bright rings produced in an experiment involving a lens with a radius of curvature of 5.0 m and a diameter of 17 mm, illuminated by light of wavelength 555 nm. Calculations using the formula m = r^2/(R*λ) - 0.5 yield varying results, with one participant arriving at 104 bright rings for air and 138 for water. Confusion arises regarding the correct values for radius and wavelength, as the book references different parameters leading to answers of 34 and 46 rings. Participants express uncertainty about their calculations and the discrepancies with the textbook answers. The discussion highlights the importance of accurately identifying the parameters in optical experiments.
threewingedfury
Figure 35-46a shows a lens with radius of curvature R lying on a flat glass plate and illuminated from above by light with wavelength . Figure 35-46b, a photograph taken from above the lens, shows that circular interference fringes (called "Newton's rings") appear, associated with the variable thickness d of the air film between the lens and the plate. The radius of curvature R of the lens is 5.0 m and the lens diameter is 17 mm.
(a) How many bright rings are produced? Assume that = 555 nm.
(b) How many bright rings would be produced if the arrangment were immersed in water (n = 1.33)?
I used the equation: m=r^2/R*lambda - .5
Definetly not getting the right answer
Can you show more of your calculation?
m=r^2/R*lambda - .5
m=.017^2/(5*555*10^-9) - .5
m=104
m=(1.33).017^2/(5*555*10^-9) - .5
m=138
I've tried 103,104, and 105 for a
and done the same for b
but the method can't be right because in the book r=20mm, R=5m lambda=589nm and the answers are a. 34 and b. 46
17 mm is the diameter, not the radius.
I don't understand, these are given in the answers?
