Newton's second law of motion questions
A discussion on Newton's second law of motion focuses on calculating the acceleration of a person with a mass of 75 kg rolling down a 15-degree hill with a coefficient of friction of 0.10. One participant calculated the acceleration to be approximately 1.55 m/s², but there is confusion regarding the correct normal force to use in the calculations. It is clarified that the normal force on an incline is not simply the weight but must account for the angle of the incline. For the second part of the problem, participants confirm that the given distance of 300 meters should be used directly in the kinematic equations. The conversation emphasizes the importance of correctly identifying forces acting on an object on an incline.
Ereny
physics help please...
a person with a mas of 75.0 kg is wearing roller blades and stands at rest on top of a long hill. the hill makes an angle of 15.0 above horizontal. assume the coefficient of friction to be .10.
a. determine the acceleration of a the person as they roll down the hill.. for this one i got around 1.55 m/s^2.. but my other friend got a different answer soo i am wandering if anyone could help me..
b. assuming the hill to be 300. meters long, that the person starts from rest, and that the acceleration remains constant the entire length of the hill, determine the person's speed at the bottom of the hill.
for b .. are we suppose to solve for distance or just use 300 in a kinematic equation?
Show how you got your result.
You're given the distance, so use it.
for a. i set up like this :
Fnet= Fll - Friction
ma=sin(15)*(mg)-u*(mg)
(75kg) a=sin(15)(75kg)(9.81)-(0.10)(75kg)(9.81)
a= 1.55 m/s^2
is it right..
and to do B i have to know acceleration from a
Almost right. The friction force equals μN, where N is the normal force. Since it's on an incline, the normal force doesn't just equal mg. What does it equal?
it equals the weight.. which is mass*gravity.. that's wt i did..
That would be true if the surface were horizontal, but it's not. To find the normal force, consider force components perpendicular to the surface. They must add to zero.
yeah but we don't have to use the perpendicular fore.. we could just use the parallel force...
and i am really confused now... can u please help me out a little more
Ereny said:
yea i know that... because they're parallel to each other.. can u please tell me if the answer is right..
You are using the wrong normal force. The normal force depends on the angle of the surface.
Read this: Inclined Planes
the normal force is the weight .. and it doesn't depend on the angle.. okay if i am using the wrong normal force wts the correct one then..
