How Do You Calculate the Mass of a Trailer Using Newton's Second Law?
To calculate the mass of a trailer using Newton's Second Law, the scenario involves a car pulling a trailer at a steady speed of 10 m/s with a pull of 100N, indicating balanced forces due to constant resistance. When the car accelerates at 0.5 m/s², the pull increases to 150N, suggesting a net force of 50N after accounting for the constant resistance. By applying the formula F=ma, the mass of the trailer is determined by dividing the net force (50N) by the acceleration (0.5 m/s²), resulting in a calculated mass of 100kg. The calculation is confirmed as correct by another participant in the discussion. This method effectively applies Newton's Second Law to find the mass of the trailer.
SeanGillespie
A car pulls a trailer along a level road at a steady speed of 10 m/s and the pull on the trailer is 100N. When the car accelerates at 0.5 m/s2 the pull on the trailer is 150N.
Assuming the resistance to motion to be constant, find the mass of the trailer.
F=ma
My assumption is that since there is no acceleration in the first case, the pull on the trailer (100N) must be balanced by a resistive force (100N). Since the resistance to motion is said to be constant, in the latter case the resistance would still be 100N.
The net force while accelerating would be 50N (150N - 100N), so using F = ma, mass should be found by dividing 50N by 0.5 m/s2.
I've calculated the trailer's mass as 100kg.
I feel uneasy about the question, it seemed fairly straight-forward, just wanting an outside opinion... have I calculated this correctly?
Your calculation looks fine to me!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
