How Much Force is Needed to Accelerate a 1000 kg Car at 2 m/s²?
To accelerate a 1000 kg car at 2 m/s², the required horizontal net force can be calculated using Newton's second law, F = ma. By substituting the values, F = (1000 kg)(2 m/s²) results in a force of 2000 N. It's important to ensure that all measurements are in SI units for accuracy. The discussion emphasizes the correct application of the formula and unit consistency. Understanding these principles is crucial for solving similar physics problems.
screaminseamin1
Newtons second law problem, show all work including units
Question: How much horizontal net force is required to accelerate a 1000 kg car at 2 m/s^2?I am not sure which formula to use in this equation
F=ma
= (1000kg)(2m/s^2)
= 2000N
ya. use the F=ma formula. but remember, all units must be SI units. this is just a general reminder.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
