Joe's Question: Nitrogen Organic Structure Property
  • Thread starter Thread starter josephcollins
    Nitrogen Organic
The discussion revolves around the structural properties of a substance with the molecular formula C7H7O2N. Key points include its reaction with sodium carbonate, which releases CO2, suggesting acidic properties rather than ionic structure. The formation of a colored complex with copper (II) cations indicates potential coordination chemistry. Additionally, the substance's resistance to addition reactions is attributed to the presence of two functional groups on a benzene ring, which may stabilize the structure and hinder such reactions. Suggestions for further exploration include using online resources like Chemfinder to identify similar compounds. The conversation emphasizes understanding the relationship between chemical behavior and molecular structure.
josephcollins
Hi ppl, I have this question. I have the MF of a substance A : C7H7O2N. I have three pieces of info which should indicate a structural property of this substance:i) A reacts with sodium carbonate to give off CO2. I thought this might indicate an ionic structure? then ii) A will form a coloured complex ion with copper (II) cations. I didn't know what this suggested really I'm afraid and finally:iii) A is unable to undergo addition reactions easily. Could someone help me with this?
Thanks, Joe
Chemistry news on Phys.org
Ortho/meta/para aminobenzoic acid is a candidate...It's an acid,gives off CO_{2} when reacted with a carbonate.It should precipitate copper.As for addition,i think those 2 groups to a benzene cycle could account for it...
Daniel.
search chemfinder to get some suggestions, and make a follow up here...show some effort.
http://www.chemfinder.com
you'll need to register first, it's free and fast.
Well, here you spoilt the opportunity to first pedagogically ask why the poster connects the release of CO2 to ionicity, followed by a discussion (trying to make the poster learn by being confused since we ask him/her if he/she really believes in a certain thing - or in the opposite :devil: ) which then eventually and hopefully could lead to a conclusion that the substance might very well be acidic. :mad:
The other things are less elementary, though.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
