Solving 3 x √27 = 3^N to Finding the Value of N
  • Thread starter Thread starter thomas49th
    Calc 3
To solve the equation 3 x √27 = 3^N, it can be rewritten as 9√3 = 3^N. By expressing both sides with a common base, it becomes clear that 9 can be represented as 3^2 and √3 as 3^(1/2). This leads to the equation 3^2 x 3^(1/2) = 3^N, simplifying to 3^(2.5) = 3^N. Thus, the value of N is determined to be 2.5.
thomas49th
Hi how do I go about finding out what N is to
3 x √27 = 3^N
this can be written as
3 x (√3 x √3 x √3)
which makes
9√3 = 3^N
now where though
i presume n must be a fraction somthing like x/2 ? x is a number? Is this right. How do i go about finding the answer?
Of only you could rewrite the equation as 3^{something} = 3^N, it would be obvious...
huh? Sorry I don't see...was that a suggestion/hint or comment
as I've got a root it does the n have a 2 as it's denominator?
An eager student would take the logs of both sides. A clever student would notice something special about this question enabling him to skip taking logs and immediately solve an equation which would give him his answer.
If you're not that clever student, take logs. Solve from there. Then see if you can see what the clever student would do.
GCSE students don't learn logs. This is on a non-calculator paper. I can't remeber what to do. I've looked in my textbook, revision book, bitesize, s-cool.co.uk and can't see somthing to help... so I turn here. Can someone show me the steps or continue my work so far? I'm doing a pratice paper and their designed to show you what you don't know... I searched books and web and had no luck :(
Since you can have LHS in terms of \ \sqrt{3}why not try expressing RHS as \ ( \sqrt{3} )^{something}
Well, you're forced to be the clever student then, aren't you! Hurkyl's post was a hint. To put it more blatantly-- try writing the left hand side as 3 to the power of something. Can you write sqrt(3) as 3^x, for some x? Can 9 be expressed as 3 to some power? Finally, can you express a product of two numbers with the same base as one number?
Interestingly enough you could write it 9√3 OR you could write it as √81 x √3... Try going on from that approach. Oh, and remember √x = x^(1/2).
I have no idea how Feldoh's first comment helps, but yes his second does. BIG Hint. Have you learned your Index Laws?
If you haven't got it yet, I'll give you a more explicit hint. x->3^x is a well defined map, ie, if x=y then 3^x=3^y.
Finally, if you still don't understand,
\sqrt{a}= a^{\frac{1}{2}}.
Even More Finally if you still don't get it, give up.
N=2.5
I still don't see...
I don't see what that means...
I know that \sqrt{a}= a^{\frac{1}{2}} but because I have a whole number and a surd I am not sure what to do. Can someone just WRITE OUT the steps they did one by one using latex?
Thx
3\sqrt{27} = 3^n
\sqrt{27}=3\sqrt{3}
Therefore:
9\sqrt{3}=3^n
3^2 \cdot 3^{\frac{1}{2}} = 3^n
Since a^m \cdot a^n = a^{m+n}, then
3^2 \cdot 3^{\frac{1}{2}} = 3^{2.5}
3^{2.5} = 3^n
n=2.5
NICE! Yeh I see now...ingenius.
Thanks for all the help :redface:
No, not ingenious- just basic formulas. Long before you attempt a problem like this you should have learned
a^x a^y= a^{x+ y}
and
(a^x)^y= a^{xy}
(I am not saying that Gib Z isn't ingenious- just that it wasn't needed here!)
