Non-zero determinant iff matrix is invertible.
5 replies · 15K views · last reply
ksm100
Given that A is any 2x2 matrix show that it is invertible if and only if det(A) [tex]\neq[/tex] 0.
If A is invertible then we know there exists an inverse matrix, say B, such that AB = BA = I.
It follows that det(AB)=det(BA)=det(I), and we know that det(I) = (1*1) - (0*0) = 1, so
det(AB) = det(A)det(B) = 1 implies both det(A) and det(B) are both nonzero.
However, I'm unsure how to show the converse.
If we suppose det(A) is not equal to 0, we know that no rows/columns of A are all zero, no two rows/columns are equal, and one row/column is not a multiple of the other.
I'm stuck here.. if anyone could help I'd really appreciate it!
Do you have any explicit formulas* for the inverse?
If not, then if you wrote down a generic matrix (its entries are variables), do you have an algorithm to compute* the inverse?
If not, can you write down another generic matrix at least solve* the system of equations that says "this matrix is the inverse of the other one"?
*: Paying careful attention to when it does and doesn't work? e.g. if you would divide by the expression (b-a), you should keep track of the fact you're assuming b-a is nonzero. (And then consider the case b=a separately)
A^(-1) = [1/det(A)]*adj(A)
So I can just say that because I know that det(A) isn't zero, 1/det(A) is defined and therefore A^(-1) exists?
Well I think that would work. I am not sure what sort of proof you are expected to give though.
Use the fact that an n*n matrix is invertible if and only if its rank is n.
