Normal Force on Vertical Plane
The discussion focuses on calculating the minimum normal force a climber needs to exert to avoid slipping in a vertical chimney scenario. The climber's weight is 686N, and the friction coefficients for the feet and back are 0.8 and 0.6, respectively. Participants emphasize the importance of using the climber's weight to determine the necessary frictional force, which must equal the weight to prevent slipping. There is confusion about calculating frictional force without knowing the normal force, as it is essential for solving the problem. The conversation encourages a step-by-step approach to clarify the relationship between normal force, friction, and the climber's weight.
bueckerjl
A 70kg climber is suppored in a "chimney" by the friction forces exerted on his back and shoes. The coeffcients of static friction of his feet against the wall and his back against the wall are 0.8 and 0.6 respectively. What is the minimum normal force he needs to apply to keep from slipping? Assume the walls are perfectly vertical and the the frictional forces are at impending slipping.
F=ma
Ff(frictional force)=mu*n(normal force)
W=mg
What I did was calculated the frictional force for the feet and the back using Ff=mu*n
What I came up with was aprox 980Newtons. Then I figured that since static friction is only used as needed, I calculated the climber's weight and I came up with 686N.
That doesn't sound right to me. What am I messing up? Thanks
Welcome to PF,
How did you calculate the minimum frictional force without using the climber's weight?
How can you calculate the friction force without knowing the normal force? (And the normal force is what you need to solve for.)
Since the friction is just barely enough to prevent slipping, what must the friction force equal?
Welcome to PF!
Hi bueckerjl! Welcome to PF! :smile:
Do problems like this one step at a time …
First step: What is the vertical force he needs to apply to keep from falling?
Second step: How will this vertical force be produced?
Your thoughts … ? :smile:
NO! Keep going! I need help on this problem. I'm stumped.
Ok so let's start over, For my example everything is the same but the guy is 78 kg
mu of the feet is 0.84 and mu for the back is 0.64.
I found mg = 764
So I need to make the vertical force resisting equal 764.
The vertical force is produce by pressing a normal force against each wall.
I don't know how to get there. I tried treating it as an inclined plane...but cos90 = 0 which means that friction is zero if friction = mu*N.
Why is that? This has nothing to do with planes.
You're basically there! Use the equation and you're done!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
