Normally Open Switch for Strobe Light Synchronization
  • Thread starter Thread starter Berzerkfury02
    Switch
The discussion centers on using a single normally open switch to synchronize three strobe lights that each have their own integrated circuit (IC) and multiple flashing patterns. The original setup uses individual switches for each strobe, but the user, Daniel, seeks to simplify the configuration by connecting them in parallel to one switch. Concerns are raised about potential circuit issues and whether this could damage the ICs. Participants suggest that the proposed configuration seems feasible and recommend testing it with two strobes first. Daniel plans to proceed with the project and will update the forum on the results after acquiring the necessary supplies.
Berzerkfury02
Hello,
I have a strobe light which is powered normally by two AAA batteries in series creating a 3 volt DC power supply. When the batteries are inserted, the circuit is closed with the exception of the switch. The strobe light is composed of five LED's which have six different ON modes because of different "chase" or flashing patterns. This switch is a normally open switch and the circuit is still open until the normally open push button switch is pushed for the first time. When pressed the completed circuit tells the IC to go to the first pattern. But pressing the button a second time tells the IC to go to the second pattern, etc. until the sixth pattern is reached. Upon reaching the sixth pattern, pushing the button one more time will tell the IC to go to the OFF position (no more flashing).
I was wondering if three strobes in parallel configuration could all use the same normally open switch in order to close the circuit for all three IC's at the same time.
I am attaching a schematic to simulate both the standard configuration (already works as it is the stock configuration found on the store shelves) and the configuration I wish to use.
I wanted to eliminate the three normally open buttons and use only one normally open push button switch to tell each of the Three IC's in each strobe light the same function at the same time (for synchronization purposes, I wanted the three strobe lights to flash the same pattern at the same exact time). I was thinking that since each switch is performing the same function (indicating to the IC that a circuit has been closed) I could eliminate the three switches and use only one. I was afraid, however, that I may be completing a circuit that was not meant to be completed by connecting the ends of the IC like this and possibly damage something, so I decided to check this with the forum here first before I tried it. Please view the schematic I had attached as it can probably explain what I am trying to do better than this text does. Would the configuration I illustrated work?
Thank You,
Daniel
I say go for it. It looks like what you've shown will work. Maybe you could just try two at first.
Regards
It looks to me like your switch is only connected to the middle strobe. The other 2 appear to connected together but it is not clear how the they will be effected by the switch. I would recommend that you connect the switch in the same manner you connected the battery.
Hard to say without knowing more about the strobe.
Well it looks like I may just have to try it,
I'm pretty sure I connected the switch the same way I had the batteries, and it looks like it's worth a try. I forgot to explain that the wires were color coded and wires of the same color are all part of the same wire. I am planning on placing both the switch and the battery in a parallel configuration for each of their own purposes so I think it would work. If it somehow does not work, I guess I will just have to live with three switches rather than just the single one I had hoped for.
As soon as I get all the supplies I need (I still need solder and proper wires), I will let everyone know how it turns out. It may be a matter of weeks until I will be able to complete this project since I will be out on vacation, but I promise to let everyone know how it turns out. I would like to thank everyone for helping me out with these problems.
Daniel
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
