What is the speed and direction of the wind in this vector problem?
  • Thread starter jemerlia
  • Tags
    Vector
In summary, the wind appears to blow from the south towards N30E for cyclist X and from the west for cyclist Y. The speed of the wind is 16km/h for cyclist X and zero km/h for cyclist Y.
jemerlia
28
To a cyclist X traveling at 8 km h-1 due east the wind appears to
blow from the south. Another cyclist Y travels at 16 km h-1 at
N30°W relative to X. The direction of the wind as experienced by Y
is from the west. Calculate the speed and direction of the wind.
Vectors - relative motion
The problem appears slightly ambiguous in that I would assume that N30W is an absolute direction. A vector diagram might be drawn:
.......WY
...XG..../YX
|WX
where
WX is wind velocity relative to X
XG is X velocity relative to ground
YX is Y velocity relative to X
WY is wind velocity relative to Y
The vectors could be added WG = WY+YX+XG
but, of course, no magnitude is given for WY and WX - only the direction.
I can't see how to proceed from here - help gratefully received :)
I wonder if taking Y's direction as an absolute value affects the problem - however I feel that if a compass bearing is quoted then it should be treated as a compass bearing - still puzzled by the word relative in "relative to X".
First of all you want to draw the cyclists as vectors traveling on their compass headings. X is easy.
X = 8 i + 0 j
However Biker Y is given relative to Biker X. This means that you need to account for Biker X's speed in determining Biker Y's true direction.
Y = - (16*Sin30° - 8) i + 16*Cos30° j
Then you need to figure what it means for Biker X to experience the wind as from the S and biker Y to experience it from the West.
Thanks for the hint. What is true is that WG (wind speed relative to the ground) must be the same for both cyclists. Following your suggestion I drew separate vector diagrams for the two cyclists:
...WG.../...|
.../...|WX WG = WX +XG
XG
WY
.YG.\.../WG WG = WY+YG
It appears that the system might generate simultaneous equations allowing solution of j and i - but although I have given myself a 1h crash course in imaginary numbers I'm unsure of the next step and its mechanism - help gratefully received :)
I think that what you can conclude is that since each perceives only West or South and they are at right angles to each other, the Bicyclist 1 motion cancels the X component and perceives just the Y component (magnitude unknown) of the wind and Bicyclist 2's motion cancels the Y component of the wind and perceives only X directed wind. (I renamed them to avoid confusion.)
Hence taking the canceling components from their motions relative to the ground, the Wind is directed as = 8 i + 16*cos30 j
You can find |wind| through ordinary means.
Please forgive my unfamiliarity with imaginary numbers. Do the i's and j's also represent the y and x co-ordinates? I am unsure how to solve the expression to find the co-ordinates.
So sorry. i,j's are simply vector notation for the vector components in the x,y directions respectively. If I could have written x-hat and y-hat more conveniently to emphasize the vector property I would have. It's just a short hand, and has nothing at all to do with imaginary numbers.
Once again - thank you. I'm still puzzled as to how solve for two unknowns in the expression for the wind direction...
After further thought it was clear that your explanation was only a trivial step short of the answer. However, I would be grateful if you would please check that my reasoning is correct:
(a) Wind direction - the expression 8x + 16*cos30y (x,y instead of i,j) points to the co-ordinates (8, 16*cos 30). This yields an angle of 60degrees which corresponds with the given answer of blowing towards N30E.
(b) |wind| = SQRT(8^2 + (16*cos30)^2) = 16km/h - which again corresponds with the given answer.
While you do have 2 unknowns - namely the x-component and y component of wind - you can solve them independently by the fortuitous circumstance that the wind as perceived by 1 is only in one dimension at right angle to his motion (and at that he's cycling along an axis) and the wind perceived by 2 is at right angle to that.
Orthogonal is a wonderful thing.
FAQ: What is the speed and direction of the wind in this vector problem?
1. What is an "obscure vector problem"?
An obscure vector problem is a mathematical problem that involves the use of vectors, which are quantities that have both magnitude and direction, but is not easily understood or commonly known.
2. How do you solve an obscure vector problem?
Solving an obscure vector problem requires a thorough understanding of vector operations, such as addition, subtraction, and scalar multiplication. It also involves using mathematical techniques, such as dot and cross products, to manipulate vectors and find solutions.
3. What are some real-world applications of obscure vector problems?
Obscure vector problems have many practical applications in fields such as physics, engineering, and computer graphics. They are used to model and solve problems involving forces, motion, and geometric transformations, among others.
4. Can obscure vector problems be solved using technology?
Yes, technology such as graphing calculators and computer software can be used to solve obscure vector problems. These tools can perform complex calculations and graphing of vectors, making it easier to visualize and solve problems.
5. Are there any strategies for approaching obscure vector problems?
One effective strategy for solving obscure vector problems is to break them down into smaller, more manageable parts. It is also helpful to draw diagrams and use vector notation to organize information and make calculations easier. Additionally, practice and familiarity with vector operations can improve problem-solving skills.
