One final problem involving electrical fields
A positively charged sphere is placed one-fifth of the distance between two negatively charged spheres, with charges of -3.0 x 10^-6 C and -6.0 x 10^-6 C, separated by 10.0 cm. To find the net force on the positively charged sphere, the Coulomb electric force equations for both negatively charged spheres must be applied, considering their distances from the positive sphere. The net force is determined by calculating the individual forces exerted by each negative sphere and then summing them. The net electric field experienced by the positive sphere can also be calculated from these forces. The point where the net electric field is zero will not be at the midpoint due to the differing magnitudes of the negative charges.
avb203796
A sphere with a charge of 5.0 x 10^-6 C is placed one fifth of the distance between two negatively charged spheres, as measured from the left. The sphere to the left has a charge of -3.0 x 10^-6 C and the sphere to the right has a charge of -6.0 x 10^-6 C. A distance of 10.0cm separates the end spheres. Calculate the net force on the positively charged sphere. In what direction is the net force? What is the net electric field that the positively charged sphere experiences? Is there a point where the net electrical field is zero? If so, where?
Ok so I am not positive how to go about solving this one. I know that teo point charges separated by given distance exert the same force on each other therefore I would think that there is a point where the net electrical field is zero and I would guess that point would be at 5.0 cm but i am not sure. where do I go from here?
How about treating the spheres as point charges? Then the location is given by the location of the center of the spheres.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elefor.html#c2
Then try starting with writing the equation for the Coulomb electric force. There is one equation for the left (-) sphere and (+) sphere, and there is a second equation for the right (-) sphere and (+) sphere.
Since the (+) sphere is one-fifth the way between, one distance is 0.2 the separation of the two negative spheres and the other distance is 0.8 the separation.
The negatively charged spheres have different magnitudes of negative charge, so the zero electric is not midway.
So then after I get the two forces do I just add them to get the net force? And after I have the net force how do I go about the rest of the problem?
