Does a measurement setup determine the reality of spin measurement outcomes?
The discussion revolves around the nature of spin measurement outcomes in quantum mechanics and whether these outcomes are determined by the measurement setup. Participants explore the implications of different interpretations of quantum mechanics, such as the Copenhagen interpretation and Bohmian mechanics, and question the reality of spin prior to measurement.
  • Some participants propose that if the outcome of a spin measurement depends on the measurement setup, it raises questions about the reality of the spin itself or the measurement process.
  • In the Copenhagen interpretation, it is suggested that spin is not real before measurement, while in Bohmian mechanics, spin is determined prior to measurement by the particle's trajectory.
  • Others argue that in Bohmian mechanics, only particle positions exist before measurement, and spin is defined as the outcome of a measurement rather than an ontological reality.
  • Some participants reference specific literature that suggests a definite spin vector exists along Bohmian trajectories, raising questions about the interpretation of spin in this framework.
  • There is a discussion about the definition of the "spin vector" and its relationship to the wave function, with differing opinions on whether it is ontological or not.
  • Participants question how spin can be measured and obtain unique results, with references to the Stern-Gerlach apparatus and the nature of measurement in quantum mechanics.
Participants express multiple competing views regarding the nature of spin and its measurement, indicating that the discussion remains unresolved with no consensus reached.
Participants highlight limitations in definitions and interpretations of spin, measurement outcomes, and the ontological status of the wave function, which remain subjects of debate.
  • #31
Demystifier said:
Yes, but q-expectations of what? Of all observables. In particular, there is an observable (essentially Hamiltonian times inverse number of particles) the q-expectation of which is the temperature.
No. Your observable ##H/N## is the mass-based energy density, which is quite independent from the temperature.
The fundamental observable quantities are the q-expectations of quantities. The latter are defined as the densely defined operators. The temperature is not such a quantity. It is instead a parameter in the grand canonical definition of the density operator.
  • #32
DarMM said:
in Bohmian Mechanics the wave function isn't considered just a tool for calculating predictions
DarMM said:
in Bohmian Mechanics the wave function is a "law of physics" thus part of the metaphysics, but not a "thing" of the theory and thus non-ontic
Don't these two statements contradict each other? I'm really confused by your terminology.
  • #33
What is the contradiction? My understanding is that there can be elements of a theory that are not "things" but are also not just epistemic quantities. For example the Euler Langrange equations are not "things" of classical theory, i.e. objects posited to exist thus not part of the ontology. They are not however epistemic, they are objective relations between the objects.
Thus they are part of the metaphysics but not elements of the ontology.
As far as I am aware this is not "my terminology" but reasonably common terminology, this article might help:
https://plato.stanford.edu/entries/metaphysics/
  • #34
I'll take a look. I am generally not a fan of using terminology in physics that is made up by philosophers instead of physics.
  • #35
Doesn't "ontology" and "epistemic" come from philosophy? Is the issue with using the word "metaphysics" in the sense of seperating "things" from "relations"?
If we don't use any philosophical terminology I guess we could say in Bohmian Mechanics the wave function is a relation obeyed by particles like the Euler Lagrange equations, an equation of motion. Not an actual propagating field like the EM field.
  • #36
You are the very first I know who calls Newton's laws or the Euler-Langrange equations for classical multiparticle systems metaphysics rather than physics.
  • #37
Yes, and I'm not a fan of those terms. IMO they lead to lots of questions which do not have well-defined answers and do not add anything useful to the physics.
We could just as well say that the EM field is "a relation obeyed by particles", since the only observations we have of the EM field are observations of particles whose motions are affected by the field. So what's the difference between the EM field and the wave function in Bohmian mechanics?
  • #38
DarMM said:
That's correct, but why does that matter for the wavefunction being non ontological?
Can an entity that is not measurable be considered as being ontological?
/Patrick
  • #39
Why do you think I also don't call them physics?
  • #40
The same encyclopedia says here that
https://plato.stanford.edu/entries/einstein-philscience/ says:
Spacetime coincidences play this privileged ontic role because they are invariant and, thus, univocally determined.
and thus attests that there is an ontic role for relations.
Maybe your usage is specific to recent quantum foundation discussions? I'd like to repeat my request for a reference where I can find a critical discussion of the term.
  • #41
/Patrick
Yes. Whether that's sensible is another question.
  • #42
DarMM said:
Why do think I also don't call them physics?
Well, maybe you do. But then this also contradicts traditional usage, which sees physics and metaphysics (''after physics'') as disjoint, though loosely related disciplines. From Wikipedia:
For instance, Thomas Aquinas understood it to refer to the chronological or pedagogical order among our philosophical studies, so that the "metaphysical sciences" would mean "those that we study after having mastered the sciences that deal with the physical world"
  • #43
How should we refer to the two different views of the wave function you see in quantum foundations?
Isn't the EM field detected in ways that aren't simply particle effects, is it true it's always the motion of particles? The difference would be that between the EM field and the Euler Lagrange equation. How would you phrase this difference?
  • #44
For instance one can look at statistical mechanics and say the phase space distribution is epistemic, but that doesn't mean one is calling statistical mechanics "epistemology" and not physics since "physics and epistemology are disjoint subjects"
  • #45
Saying ''the phase space distribution is epistemic'' does not make the phase space distribution metaphysics but only this statement about it. The phase space distribution itself is physics and not metaphysics.
Thus "physics and epistemology are disjoint subjects", though they are loosely related in as much as epistemology uses physical concepts as objects of discourse.
  • #46
Whatever terms we use, they are terms of philosophy (or perhaps "metaphysics"), not physics. Both views agree on all predictions for actual experiments, so whatever difference there is between them is not a matter of physics.
What ways? Can you give an example?
  • #47
So are we to talk about them at all? They are divisions in approaching QM that have led to highly cited results. If you prefer not to use them then how do we deal with the fact that they're commonly used and motivate research?
I think this might go off on another difficult tangent. I think it's better to focus on the basic difference. To you is there a distinction between the electric field and the Euler Langrange equations? If yes, the wave function in Bohmian Mechanics is like the latter.
  • #48
Yes, it is the same above regarding Euler Lagrange equation. They're physics, but that classification is a metaphysical one.
  • #49
Why?
  • #50
  • #51
The classification of particle positions in Bohmian mechanics as 'real' or 'ontic' - i.e., the common interpretation of Bohmian mechanics - is also metaphysical, though Bohmian mechanics itself is, as an extension of the quantum mechanical formalism, (potentiallyy falsifiable) physics.
  • #52
DarMM said:
Part 12 of this paper has an exposition
So basically, the criterion being given is that for something to be "real" it must be capable of being acted on by other "real" things, whereas the wave function is not acted on by anything. But this doesn't seem right, because the wave function is determined by Schrödinger's Equation, which includes the potential energy, and the potential energy is a function of the particle configuration. So I don't think it's correct to say that the wave function is not acted on by anything.
  • #53
I don't necessarily disagree, I was only stating what the "common" Bohmian position is.
  • #54
Agreed.
  • #55
Without particles, there is no physical system which could be described by a wave function (in non-relativistic QM). There could still be an electric field because the Maxwell equations admit vacuum solutions. To me, this seems like an important difference and it justifies the view of the electromagnetic field as a physical system in its own right instead of a tool to describe particle interactions.
  • #56
But the coordinates are dummy variables, not Bohmian positions.
  • #57
This seems to me to be a red herring. "Vacuum solutions" of the Maxwell equations just means there's no charge-current density "source" on the RHS. But there is no analogue to this "source" in Schrödinger's Equation anyway; the only "current density" is ##\psi^* \psi##, which is always "there" anyway.
Also, talking about particles as the only "physical system which could be described by a wave function" already presupposes that the wave function itself is not "real". If the wave function itself is "real", there doesn't need to be any other physical system that it describes; it is a physical system all by itself.
  • #58
I need to better understand what you mean by the wave function being a physical system in order to comment on this. Right now it doesn't seem sensible to me to compare the equations like this.
I just noted that in non-relativistic QM, the notion of particles (or more generally the notion of the physical system) comes before the notion of the wave function.
Similarly, in classical mechanics, the notion of particles comes before the notion of velocity. I wouldn't say that velocity being secondary to particles makes it not "real" but since "real" is notoriously ambiguous (in this thread alone, I count at least three different usages) I'd like to avoid this terminology completely.
If you are saying that I presuppose that the wave function is not a physical system similar to velocity not being a physical system in classical mechanics, I agree that I do this.
PeterDonis said:
If the wave function itself is "real", there doesn't need to be any other physical system that it describes;[...]
Also in dBB -which the discussion seemed to be about- there needs to be a physical system which determines the observables. No such system, no wave function.
PeterDonis said:
[...] it is a physical system all by itself.
I have a hard time wrapping my head around this.
It makes a certain sense to me to regard the electromagnetic field as a tool for accounting for complicated direct particle interactions which gives it the same status as the wave function in Copenhagenish interpretations. That we usually don't do this but imagine the electromagnetic field as an independent entity has clear reasons: I can shoot a light pulse into empty space and have a mathematical description for what happens there in the absence of matter. This motivation is absent for the wave function. I cannot create a wave packet which propagates in the absence of matter (in NRQM). No matter, no wave function.
What does make a certain sense to me is to question the primacy of matter and say that the wave function and matter are intertwined. But I don't see any motivation to treat the wave function as a physical system all by itself.
  • #59
Yes, agreed.
I don't agree with this. The wave function is a separate thing from the Bohmian particle positions. It even has its own evolution equation (I know I said earlier that I thought that equation depends on the particle positions through the potential energy, but after @A. Neumaier's response to that I'm not so sure). So it's perfectly possible to look at the wave function in dBB as a separate entity, not dependent on particle positions.
  • #60
@kith and @PeterDonis points of view can be reconciled by differentiating between the abstract physical system (n scalar particles in 3-space) and a concrete physical system (defined by its trajectory of states) providing an instance of it. The former is prior to the latter and determines the kinematics, but the latter is needed to make predictions.
  • · Replies 35 ·
  • · Replies 114 ·
  • · Replies 40 ·
  • · Replies 37 ·
