Optical Path Length: Calculate w/ Refractive Index & Length
To calculate the optical path length of a light beam passing through different media, the formula used is the product of the refractive index and the physical distance for each medium. In this case, the beam travels through 2.0 inches of glass (n=1.525), 12 inches of water (n=1.33), and 0.6 inches of polystyrene (n=1.590), resulting in an optical path length of approximately 20 inches. The discussion clarifies that there is no need to consider angles or triangle geometry since the light is assumed to be perpendicular to the interfaces of the materials. Therefore, simply multiplying the refractive index by the corresponding lengths and summing them is sufficient for the calculation. The conclusion is that the initial approach to calculating the optical path length was correct.
istinkatphysics
This is the question:
The optical path length of a light beam is nd where n is the refractive index and d is the physical distance. A light beam passes through 2.0 in thick glass (n=1.525) and then through 12 in. of water (n=1.33) and finally though 0.6 in of polystyrene (n=1.590). What is the optical path length?
Is this too easy to just multiply the refractive index by the length and then add all of those numbers? When I did that I got about 20 inches. I was also wondering if I missed a trick or anything in this problem. The length could be different (instead of using the values of 2 in, 12 in, and 0.6 in) because the light becomes bent (with the refractive index). Does this set up a triangle in the glass, water, and polystrene? Is only the one side of the triangle 2 in and i am looking for the hypotenuse as a length value? If so how would i calculate that with no angles (or only a 90 degree one)?
Thanks for reading.
This is correct. I also get about 20.
Nope!
The light only refracts if it's incident at an angle to the interface. Since they don't give you an incident angle, it's safe to assume that the light is initially perpendicular to each interface and all the interfaces are parallel to each other.
