Optics homework: Why is this equation called a standing wave?
The equation ψ(y,t)= -2A sinky sin wt represents a standing wave, which oscillates in time while maintaining a constant peak amplitude profile in space. This phenomenon occurs due to the superposition of two identical waves traveling in opposite directions, creating a disturbance that does not propagate. Unlike destructive interference, where waves cancel each other out at a point, standing waves result from the continuous interaction of these waves without movement. The key characteristic of standing waves is that oscillations at different points are in phase, leading to a stationary pattern. Understanding this concept is essential in optics and wave mechanics.
noobmaster69
Optics help
Why is this called a standing wave?
"In physics, a standing wave, also known as a stationary wave, is a wave which oscillates in time but whose peak amplitude profile does not move in space. The peak amplitude of the wave oscillations at any point in space is constant with time, and the oscillations at different points throughout the wave are in phase."
source: https://en.wikipedia.org/wiki/Standing_wave
noobmaster69 said:
Homework Statement:: Optics help
Relevant Equations:: .
The equation that you wrote is mathematically equivalent to the sum of two waves of identical wavenumber
##k## and angular frequency ##\omega## traveling in opposite directions, $$ \psi(y,t)=A \sin(ky-\omega t)+A\sin(-ky-\omega t).$$Many people erroneously believe that, when two identical waves traveling in opposite directions are added, they "cancel each other out". This is not the case. Think of waves as disturbances of the medium they travel in. In contradistinction to producing no disturbance at all, two identical disturbances traveling in opposite directions produce a disturbance that goes nowhere, i.e. a standing wave.
To "cancel each other out" at a given point in space ##y_0##, the added identical disturbances must be traveling in the same direction and have a phase difference of π at all times. The name for this is "destructive interference" and is mathematically described as the sum of two waves thusly$$\psi(y_0,t)=A \sin(ky_0-\omega t)+A\sin(ky_0-\omega t-\pi).$$
