Optics, lenses, and light reflection
The discussion revolves around building a laser range finder, with a focus on the challenges of focusing a reflected laser beam onto a silicon photodiode. The user seeks assistance in optics, particularly in finding suitable lens assemblies and understanding light reflection from surfaces. Key concerns include the specifications for the lens diameter, type, and the ability to focus light through rotation. Additionally, there are inquiries about calculating the amount of reflected light when a laser beam hits a white surface. The user aims for a range of one to 100 feet and is using specific components like an avalanche photodiode and a prototype laser module for the project.
Ray_Xu
Hi, I'm new to this place, and I'm not sure if my problem fits with this forum, but I'll give it a try.
Right now, I'm building a laser range finder, but my biggest concern will be focusing the reflected laser beam onto a small silicon photodiode. And to add to that, I have barely any knowledge in optics except for the types of lenses, and some terms used in optics. It would be best if there is some manufacturer/distributor that sells lens assemblies (custom or standard). Here are my requirements, so
far:
1. diameter: between/equal 5 inches and 2 inches 2. type: convex, or a lens assembly to focus light 3. no filtering (for now).
4. can be focused by using a rotating motion (such as those on a nikon D70 camera)
Also, I'm having trouble on calculating the amount of reflected light if I were to fire a laser beam at a white surface. Can anyone help me on this?
Ray Xu
Science news on Phys.org
You are untaking a project that is going to be extremely difficult, given your level of preparation. At least look around and see what information about range finders is out there (e.g. principles of operation). For example, what is your requirement for distance accuracy? What wavelength? Field of view? Speed of acquisition?
Focusing the (reflected) light onto a photodiode is the least of your problems.
I already have all the electronics and everything planned out and to be simulated (electronics is basically my living). The only part where I really lack is optics; which I need to patch it up before I can move on.
If you make the laser source confocal with the photodiode, then your problem is solved. Use whatever lens system you use to launch and steer the source to collect and focus the return signal.
Interesting and good Science Fair project. How long a distance do you want to range? What time resolution do you want? What are properties of the photodiode - speed (risetime), sensitive area, noise, etc? What are the properties of the laser- pulse length, joules, wavelength, divergence?
Actually, this isn't a science fair project (although I did enter part of my project into the science fair). This is my hobby and I plan to sell it to some major company to mass produce it. To answer your questions, the range I'm aiming for is from one or two inches to 100 feet. Accuracy will depend on the range setting (nature of the phase detector's design). I'm using a avalanche photodiode in my receiver circuit from Hamamatsu; costs $80 (pretty cheap but yet its perfect for my application). Right now, I'm using a prototype laser module that is 659nm in wavelength, 3.5mW maximum output power, and modulation capable; bought it from Meredith Instruments.
Edit: and I have a blog here if you are interested in my progress on it; http://rayxublogs.blogspot.com/ (yes I have bad English)
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
