At what distance is the object from the mirror?
  • Thread starter Thread starter dmolson
    Mirror
An object is positioned in front of a convex mirror with a 65 cm radius of curvature, resulting in a virtual image that is half the size of the object. The focal length is calculated as -32.5 cm due to the nature of the convex mirror. The correct relationship between the object distance (p) and the image distance (q) is q = -0.5p. The forum participants advise using this relationship in the mirror equation to find the object distance. A misunderstanding of the calculations led to incorrect results, emphasizing the need to correctly apply the image size relationship.
dmolson
An object is placed in front of a convex mirror with a 65 cm radius of curvature. A virtual image half the size of the object is formed. At what distance is the object from the mirror?
1/p + 1/q = 1/f
I have tried this problem several times different ways and cannot get the correct solution. I tried it this way.
focal length = Radius of curvature/2 = -32.5 cm (negative because convex mirror
virtual image = 1/2 object = -q
object = + p
I obtained 16.25 using equation 1/p -1/32.5 = -1/32.5, but it is wrong, as well as -16.25. Any help would be great.
"virtual image = 1/2 object = -q"
You didn't use this correctly in your calculation. The question says the image is half the size of the object, so that means q = -0.5p. You can use that in your equation. I don't understand why you have -1/32.5 twice there.
object = + p
You're on the right track here, but you didn't follow through. Hint: Write the image distance (q) in terms of the object distance (p). Then apply that to the mirror equation.
Not sure what you are doing here. Redo this given my advice above. (And realize that a negative value of p would imply that the object was inside the mirror!)
(Looks like hage567 beat me too it while I was daydreaming.)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
