How to Optimize a Multi-Diameter Shaft with Varied Components in MATLAB?
  • Thread starter Thread starter JoeS4
    Design Shaft
To optimize a multi-diameter shaft with two bearings and two gears in MATLAB, start by defining fixed parameters such as gear and bearing positions, power transfer requirements, and material properties. Create a parameterized diagram to visualize the shaft's design, identifying the relationships between the various components. Determine the number of free parameters available for optimization after accounting for fixed elements. Consider the type of bearings and gear specifications, as these will influence the optimization process. Using MATLAB, implement graphical tools to analyze how changes in unknown variables affect the shaft's performance.
JoeS4
How would you go about designing a shaft with 2 bearings, 2 gears, and the shaft has various diameters (d1, d2, d3)?
You know how much power needs to be transferred from one gear to another, the distance between both of the gears, the minimum allowed distance between gear and bearing centers, the material of the shaft, rotational velocity of input gear, the maximum length of the shaft, there will be 2 shoulders, input gear is somewhere along the second diameter, output gear is somewhere on the third diameter, bearings are somewhere on the first and third diameters.
I'd like to use a program like MATLAB for optimization to graphically identify changes as unknown values fluctuate. With so many unknown variables, how would you recommend approaching this?
If the gears have been designed and it is only the shaft that you wish to optimise then you probably know where the gears and bearings must be on the shaft. Do you know what type of bearings they will be? Are the gears straight cut or helical? Left or Right handed? Driven or driving?
Draw a diagram showing your hypothetical shaft. Parameterise the diagram.
Now, there are a number of parameters that are fixed.
How many parameters remain free?
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
