Optimum Oil Pipeline Flow Rate & Angle
khfrekek92
You wish to design an oil pipeline such that the flow rate under gravity alone will be as large as possible while remaining non-turbulent. the diameter is .45m, the viscosity is .385 n-sec/m^2, and the reynolds number is 2000.
(a) what is the maximum flow rate you can achieve?
(b) what should be the slope of the pipeline (m/km)?
(c) is this a feasible way to design a pipeline?
Vc=Rn/rho(D) (critical velocity)
By using the above reynolds equation I've found that the maximum velocity before turbulence to be 2.01 m/s. Then I assume that I multiply this by the area (pi(.45/2)^2) to get the maximum flow rate? Is that right? Then I have no idea how to find slope of the pipeline afterwareds.. any help is much appreciated!
It depends on what tools you have rather what tools you can use/comfortable with. Basic theory & computations, via the bernoulli's equation for inviscid flow, can get you a basic answer based on raw calculates for pressure, density, elevation, etc.
If you also add factors like minor head loss, major head loss, fricitional losses, changes in head,
you can easily make some raw pipeline designations for this .. if you don't know the equations.. see attached.. they are given in these examples...
If you are a grad. student, then things like computational work, navies stokes, etc. will do equally as well and better..
best
Oh wow that all looks so complicated, probably too much so for my physics class, which is just an honors-level 2nd year physics major class.. Is flow rate simply just Av?
no it is pretty simple like those equations...
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
