Calculating Energy for Orbital Deployment
To calculate the energy required to deploy a 100kg package into orbit at 1,000 km above Earth's surface, the gravitational force must be considered, as it decreases with height. The initial calculations provided were incorrect due to a misunderstanding of the work done against a non-constant gravitational force. Potential energy equations can be utilized to determine the work done by gravity more accurately. The discussion highlights the need for a correct approach to find the total energy required for both reaching the altitude and achieving a stable circular orbit. Accurate calculations are essential for determining the deployment costs effectively.
ashvuck101
A scientist wants to put an 100kg experimental package in orbit around the Earth. The cost of deployment depends on the amount of extra energy it takes to get it into the required position i.e. how much more energy is used than just sending the rocket up there.
a) Determine the amount of work that must be done to get the package to 1 000km above the Earth’s surface.
b) Determine the amount of extra work needed to put the package into a circular orbit at this height.
Ep=-Gm1m2/r
w=fd
f=Gm1m2/r2
using
f=Gm1m2/r2
= 9.83*102
w=fd
= 9.83*102*100000
= 9.83*107
b)
im not sure if a is right and i don't know how to get the answer for b
somebody at least tell me i am going in the right direction here
Hi ashvuck101,
Ep=-Gm1m2/r
w=fd
f=Gm1m2/r2
using
f=Gm1m2/r2
= 9.83*102
Okay, this is the force of gravity on the object at the Earth's surface.
w=fd
= 9.83*102*100000
You seem to be missing a zero here for the distance.
But more importantly, this approach is what you would use if the gravitational force were constant over the entire 1000 km. (Because to find the minimum energy, you would set the pushing force to be equal to the gravitational force.) However, gravity decreases with height. How do you find the work of a force that is not constant?
As an alternative, what is the definition of potential energy? How can that help you find the work done by gravity?
= 9.83*107
b)
