Organizing Your Physics Calculations: Tips and Examples
Organizing physics calculations can enhance clarity and presentation. A common approach includes starting with a problem statement and relevant diagrams, followed by listing known values and equations. The calculation process typically involves detailed mathematical steps leading to a clearly marked solution. While strict formatting is not always required, some instructors may specify preferences, such as presenting the final answer in a complete sentence. Overall, maintaining a structured format can improve the readability of assignments without risking marks for presentation.
annalise17
This doesn't really go in the format for this section but I don't think it fits anywhere else...
Does anyone have examples of how they write up their solution to problems? I have one based around special relativity and I want to keep everything in a nice order so I wondered if anyone had anything a little more organised than my scribbles!
Mine is basically:
Diagram
Known Values
Equation
Where x is... etc.
Rearranging for x gives:
Substituting the known values gives:
Answer
Summary: Therefore the value of x is... (? sf)
Unless your prof explicitly states that he/she wants it in a specific format then it really doesn't matter. My assignments usually consist of:
Problem statement (what are we trying to find/prove and any diagrams)
Relevant equations (sometimes numbered so I can refer back to them)
math
math
math
math
math
solution (Circled and with arrows to it so the TA knows what the final answer is)
Usually it doesn't follow any strict guidelines. I have never been docked marks for messiness.
Edit - I had one class where the prof explicitly stated that she wanted the final answer in a sentence and 'boxed' at the end. That was the only time I've ever been given 'guidance' towards how to format my assignments.
Thanks :) I haven't written relevant equations at the start before so I might just do that now to neaten things up :)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
