Orthogonal vector spaces and matrices
julie94
Hi everyone,
I would need to get some help on the following question
Let A (m*n)
Let B (m*p)
Let L(A) be the span of the columns of A.
L(A) is orthogonal to L(B) <=> A'B=0
I suppose that the => direction is pretty obvious, since A is in L(A)
and B in is L(B).
Now I am not sure how to attack the <= statement. I guess that every
vector in L(A) is generated by the rows of A, and every vector in L(B)
is generated by the columns of B.
Therefore A'B=0, means Sum(i, j, constant_i*row_i of
A*constant_j*row_j of B).
How can I improve my argument?
julie94 said:
Hi everyone,
Let A (m*n)
Let B (m*p)
and B in is L(B).
Not exactly. Each column of A is in L(A), and each column of B is in L(B).
I assume by A' you mean A^T, the transpose of A, or if you're working over the complex field, it would have to be A^H, the conjugate transpose of A. If so, then each element of A'B is formed by computing the inner product between one column of A and one column of B. By the orthogonality assumption, each inner product is 0, and therefore so is A'B.
That's the right idea, though you mean "every vector in L(A) is generated by the columns of A", or "every vector in L(A) is generated by the rows of (A')".
I suggest writing down an expression for the (i,j)'th element of A'B and setting it equal to zero. This will show that any column of A is orthogonal to any column of B. You then need to show that this implies that any element of L(A) is orthogonal to any element of L(B). (Hint: by definition, the columns of A are a basis for L(A), and similarly for B.)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
