Oscillating String - Transverse Speed, what am I doing wrong?
The discussion centers on calculating the transverse speed of a particle on an oscillating string described by the equation y´ = (0.654 cm) sin[(π/4.0 cm-1)x] cos[(24.2π s-1)t]. The correct transverse speed at x = 1.24 cm and t = 1.13 s is determined to be 36.4 cm/s, achieved by correctly applying the partial derivative with respect to time. The initial miscalculation was attributed to incorrect use of calculator settings, specifically the mode of radians. The participant successfully resolved the issue by using Wolfram for verification.
  • Understanding of wave equations and oscillation principles
  • Proficiency in calculus, specifically partial derivatives
  • Familiarity with trigonometric functions and their applications in physics
  • Experience with scientific calculators and software like Wolfram Alpha
  • Review the principles of wave motion and superposition in physics
  • Learn about calculating transverse speed in oscillating systems
  • Explore the use of Wolfram Alpha for solving complex equations
  • Study the importance of calculator settings in mathematical computations
Students and professionals in physics, particularly those studying wave mechanics, as well as anyone needing assistance with calculus applications in oscillatory motion.
Malavin
A string oscillates according to the equation
What are the (a) amplitude and (b) speed of the two waves (identical except for direction of travel) whose superposition gives this oscillation? (c) What is the distance between nodes? (d) What is the transverse speed of a particle of the string at the position x = 1.24 cm when t = 1.13 s?
Give your answers in centimeter-based units.
I only need help with part d, the other parts I have gotten right.
Here's my attempt at solving:
u = ∂y´/∂t = (0.654 cm) (24.2π s-1) sin[(π/4.0 cm-1)x] (-1) sin[(24.2π s-1)t]
Then, plugging in x and t:
u = (-0.654 cm) (24.2π s-1) sin[(π/4.0 cm-1)(1.24 cm)] sin[(24.2π s-1)(1.13 s)]
u = -32.9 cm/s
When I plug this solution in, I am told that it is not the correct answer. Even when I tried neglecting the negative sign. I am not sure how my calculations are wrong, but I would love to be enlightened!
Your method looks fine. I get a different number. Are you sure your calculator is in radian mode?
Oops! I looked at the equation again and it's π/4.0 cm-1, not 4.0π. That is what I used to get the result I did. I have gone back and edited my original post to reflect this. I hope that when calculated with π/4, you get the same thing as I do.
EDIT: Okay, apparently my method was right, but there is something wrong with my calculator. Just plugged in the numbers to Wolfram and received 36.4 cm/s which is the right answer.
Final Edit: Yes, I must have been using parentheses dumb or something. Just plugged it into my calculator again and got 36.4 cm/s. I feel dumb now, but I got the right answer after all! :)
Thank you for your help!
