Does Elevator Acceleration Affect the Oscillation Period of a Spring?
The discussion focuses on how the acceleration of an elevator affects the oscillation period of a mass attached to a spring. The relevant equation for the period of oscillation is T=2pi * sqrt(m/k), which does not explicitly include acceleration. However, the increased acceleration due to the elevator's upward motion alters the equilibrium position of the spring. This change in equilibrium affects the effective force on the mass, leading to a different oscillation period. Therefore, the period of oscillation is not the same when the elevator is accelerating compared to when it is at rest.
okgo
A mass attached by a light spring to the ceiling of an elevator oscillates vertically while the elevator ascends with constant acceleration. Is the period greater than, less than, or the same as when the elevator is at rest
T=2pi * sqrt(m/k)
Since the equation doesn't account for acceleration, is the period the same?
T=2pi * sqrt(m/k)
That is correct.
The increased acceleration (g + a) serves to alter the relaxed length at equilibrium.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
