Oscillation (particle movement)
A particle rotates counterclockwise in a circle with a radius of 4.4 m and an angular speed of 11 rad/s. At t = 1.22 s, the x coordinate of the particle's velocity was calculated using two methods, with the second attempt yielding a value of approximately -3.29 m/s. The x coordinate of the particle's acceleration was found to be 71.14 m/s², confirming the calculations were correct. The discussion also included a request for study advice for an upcoming test on various physics topics, with suggestions to continue problem-solving and consider additional resources. Overall, the participant expressed a desire for effective study methods in physics.
Schulze
of radius 4.4 m with a constant angular speed
of 11 rad/s. At t = 0, the particle has an x
coordinate of 2.9 m and y > 0 .
Part 1: Determine the x coordinate of the particle velocity
at t = 1.22 s.
Answer in units of m/s
Part 2: Determine the x coordinate of the particle acceleration
at t = 1.22 s.
Answer in units of m/s2
x = Acos(wt + d)
where d was found in a previous part of the problem and confirmed correct by the program to be:
d = 0.8511870029
v = -wAsin(wt + d); vx = -wRsin(wt) = -vsin(wt)
a = -w2Acos(wt + d)
Note R and A are interchangeable
Part 1:
Attempt 1: v = -wAsin(wt + d) = -(4.4 m)sin(11rad/s * 1.22s + 0.8511870029)
v = -4.360544081 m/s
Incorrect
Attempt 2: vx = -wRsin(wt)
vx = -(11rad/s)(4.4m)sin(11 rad/s * 1.22 s) ≈ -36.477666 m/s
vx = -vsin(wt) = (solution from Attempt 1)sin(wt)
vx = -(-4.360544081 m/s)sin(11 rad/s * 1.22 s) ≈ -3.286414681 m/s
Vastly different answers, don't know if incorrect because I don't want to get points deducted from score from trying random answers
at t = 1.22 s.
at t = 1.22 s.
x = Acos(wt + d)
d = 0.8511870029
a = -w2Acos(wt + d)
Part 1:
Incorrect
Attempt 1: v = -wAsin(wt + d) = -(4.4 m)sin(11rad/s * 1.22s + 0.8511870029) is almost correct. You put A=4.4m into -wA. What happened to the w?
that's true. So if I multiply my result by 11 rad/s I get:
v = -47.96598498 m/s
However, is this total velocity in both x and y directions or is it the x coordinate of the velocity?
I would think that it would be the x coordinate, since we are taking the derivative of the position of the x coordinate?
Ok part 1 is correct!
at t = 1.22 s.
a = -w2Acos(wt + d)
a = -(11 rad/s)2(4.4 m)cos((11 rad/s * 1.22 s) + 0.8511870029)
a = 71.13887508 m/s2
which is correct!
Thank you.
But now I have more of a conceptual question that I would like to ask? Or rather, methodological?
I have a test coming up in 2 days over Dynamics of a Rigid Body, Statics and Elasticity, Oscillations, and Waves. (All in my Mechanics class)
Since it is my freshman year, taking mechanics, as a Physics major, I was wondering how it is that others study physics, or if you both could give me words or advice on how I should approach the study of physics.
Up until this point, I would read the textbook, work problems relevant to the readings, and if I was still confused I would Google the problem or concept.
I am not dissatisfied with this method, but I was just looking for someone else's perspective.
at t = 1.22 s.
Answer in units of m/s2a = -w2Acos(wt + d)
which is correct!
Thank you.
Very welcome! What you are doing sounds fine to me, it worked for me. Except I didn't have google. But if you want more opinions on this there is a separate forum called Academic Guidance. You might want to post there. You'll probably get too many opinions, but there you go.
Likes 1 person
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
