##p(\sqrt 3+\sqrt 2)=(\sqrt 3)-1## find minimal ##p(x)## polynomial
  • Thread starter Thread starter littlemathquark
    Algebra Polynomial
The problem involves finding the minimal polynomial \( p(x) \) such that \( p(\sqrt{3}+\sqrt{2}) = \sqrt{3} - 1 \). The context is rooted in algebra, specifically in the study of polynomials with rational coefficients and their degrees.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the degree of the polynomial needed, with some suggesting that a degree of four may be necessary for the minimal polynomial of \( \sqrt{2} + \sqrt{3} \), while others propose that a degree of two might suffice if using \( \sqrt{3} \) as coefficients. There are attempts to express \( p(x) \) in terms of known values and to manipulate equations involving powers of \( \sqrt{2} + \sqrt{3} \).
There are multiple interpretations of the problem, with some participants providing specific polynomial forms that satisfy the equation. The discussion includes calculations of powers of \( \sqrt{2} + \sqrt{3} \) and their implications for determining the polynomial's form. Some participants express uncertainty about the degree of the polynomial and explore the implications of linear independence of the involved square roots.
Participants note that the minimal polynomial must have rational coefficients and discuss the implications of the degrees of polynomials in relation to the linear independence of \( \sqrt{2} \) and \( \sqrt{3} \) over \( \mathbb{Q} \).
littlemathquark
##p(\sqrt 3+\sqrt 2)=(\sqrt 3)-1## find minimal ##p(x)## polynomial with rational coefficient
I have tried ##p(x)=ax^3+bx^2+cx+d## but this is a long way. How can I solve easily that question?
littlemathquark said:
Homework Statement: ##p(\sqrt 3+\sqrt 2)=(\sqrt 3)-1## find minimal ##p(x)## polynomial
Relevant Equations: ##p(\sqrt 3+\sqrt 2)=(\sqrt 3)-1## find minimal ##p(x)## polynomial with rational coefficient
I'm not quite sure what you are looking for, the minimal polynomial of ##\sqrt{2}+\sqrt{3}## or a polynomial of minimal degree that satisfies ##p\left(\sqrt{2}+\sqrt{3}\right)=\sqrt{3}-1.##
If it is the former, then you will probably need a polynomial of degree four.
If it is the latter, then a standard method should be to multiply the equation by ##\sqrt{3}+1=p\left(\sqrt{2}+\sqrt{3}\right)+2.## Maybe we can get away with ##\deg p(x)=2## since we can use ##\sqrt{3}## as coefficients.
I'm looking for polynomial of minimal degree that satisfies ##p\left(\sqrt{2}+\sqrt{3}\right)=\sqrt{3}-1##
But ##p(x)=\dfrac{-x^3+11x}{2}+1## satisfies ## p(\sqrt{2}+\sqrt{3})=\sqrt{3}-1##
I haven't solved it for you. Now I changed that. Calculate ##\left( \sqrt{2}+\sqrt{3} \right)^3## and express it in terms of ##p\left( \sqrt{2}+\sqrt{3} \right)## and ##\left( \sqrt{2}+\sqrt{3} \right).## That makes seven lines total.
I found that solution:
##x=\sqrt2+\sqrt3##
##x^3=9\sqrt3+11\sqrt2##
##11x-x^3=2\sqrt3##
##\sqrt3=\dfrac{11x-x^3}{2}##
Can you share detaile your solution?
Bu the way the correct ##p(x)=\dfrac{11x-x^3}{2}-1## not plus 1,sorry.
##x=\sqrt2+\sqrt3##
##x^3##=9\sqrt3+11\sqrt2
##11x-x^3=2\sqrt3##
I first calculated the low powers of ##\sqrt{3}+\sqrt{2}## since they are crucial for any approach to this question. It is something you can do without wasting too much time. It is like equipping your toolbox with additional screw drivers. So I got
\begin{align*}
\left( \sqrt{2}+\sqrt{3} \right)^2&= 2 \sqrt{6}+5\\
\left( \sqrt{2}+\sqrt{3} \right)^3&= \left( 2\sqrt{6}+5 \right) \left(\sqrt{2}+\sqrt{3}\right)\\
&=4\sqrt{3}+ 5\sqrt{2}+6\sqrt{2}+5\sqrt{3}\\
&=9\sqrt{3}+11\sqrt{2}\\
&=11\left( \sqrt{2}+\sqrt{3} \right)-2\sqrt{3}\\
&=11\left( \sqrt{2}+\sqrt{3} \right)-2p\left( \sqrt{2}+\sqrt{3} \right)+2
\end{align*}
and re-arranging the last equation yields the desired result
p\left( \sqrt{2}+\sqrt{3} \right)=\dfrac{11 \left( \sqrt{2}+\sqrt{3} \right)-\left( \sqrt{2}+\sqrt{3} \right)^3}{2}+1
I forgot that we also have to show that ##\deg p(x)=3## is the minimal possible degree.
If ##\deg p(x)=1## then
\begin{align*}
p(x)&=ax+b\\
p\left(\sqrt{2}+\sqrt{3}\right)&=a\sqrt{2}+a\sqrt{3}+ b=\sqrt{3}-1
\end{align*}
and thus ##a=0## contradicting ##b\in \mathbb{Q}## since ##\sqrt{2}## and ##\sqrt{3}## are lineraly independent over ##\mathbb{Q}.##
The case ##\deg p(x)=2## is a bit longer but along the same lines: ##\{\sqrt{2},\sqrt{3},\sqrt{6}\}## is ##\mathbb{Q}##-linearly independent.
  • · Replies 18 ·
  • · Replies 58 ·
