Packaged dropped from Hot Air Balloon
  • Thread starter Thread starter dvdqnoc
    Air Balloon Hot
A package is released from a hot air balloon traveling upward at 2.6 m/s from a height of 19 m. The acceleration due to gravity is -9.8 m/s², and the vertical displacement of the package is -19 m as it falls to the ground. The equation d = v1*t + (1/2)at² is used to solve for the time the package is in the air. The initial velocity (v1) is 2.6 m/s, but it is considered negative in the context of the downward motion. By substituting the values into the equation, the time of flight can be calculated.
dvdqnoc
A Hot air balloon is traveling vertically up-
ward at a constant speed of 2.6 m/s. When
it is 19 m above the ground, a package is
released from the balloon.
The acceleration of gravity is 9.8 m/s^2.
After it is released, for how long is the
package in the air? Answer in units of s.
http://www.glenbrook.k12.il.us/gbssci/phys/Class/1DKin/U1L6a1.gif
I tried doing X = .5at^2 + vit and using -2.6, but it didnt work.
you can solve the problem directly with:
d = v1*t + (1/2)at^2
what is d? what is v1? what is a?
well a is -9.8 because of gravity.
Vi is 2.6, but its the opposite direction of falling. So what do I do with it?
d is 19 m.
I don't know how to use that equation because the Velocity is upward, but the object is falling DOWN.
d is 19 m.
d is -19m. becuase the object drops a distance of 19m. ie: vertical displacement = final height - initial height = 0m - 19m = -19m.
plug in a = -9.8, vi=2.6 and d = -19 into the equation...
solve for t.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
