Calculate Forces on Parachute & Person: Parachute Homework
  • Thread starter Thread starter A_lilah
    Forces Parachute
The discussion revolves around calculating the forces acting on a parachute and a person during a parachute descent. For a 78 kg person experiencing a downward acceleration of 2.8 m/s² and a parachute weighing 5.4 kg, the upward force exerted by the air on the parachute was calculated as 1050.84 N. The downward force exerted by the person on the parachute, including the tension in the string and the person's weight, was found to be 1747.2 N. However, the calculations were noted to have sign errors, as the net force must align with the direction of acceleration. Correcting these signs is crucial for accurate results in the physics problem.
A_lilah
A 78 kg person is parachuting and experiencing a downward acceleration of 2.8 m/s2. The mass of the parachute is 5.4 kg.
(a) What upward force is exerted on the open parachute by the air?
(b) What downward force is exerted by the person on the parachute?
Fnet = ma
Forces on parachute:
Weight of parachute => W1 = mg = 5.4kg * 9.8 m/s^2 = 52.92N down
Force of Air on parachute => A N up
Tension of string => T N down
Forces on Person:
Tension of string => T N up
Weight of person => W2 = 764.4 (found the same way as above) down
Fnet on the person = 78kg * 2.8 m/s^2 = 218.4 N = T - 764.4N
solve for T... T = 982.8N
Fnet on parachute = 5.4kg * 2.8m/s^2 = 15.12N = A - T - W1,
T and W1 known:
15.12N = A - 982.8N - 52.92N
solve for A... A = answer to question (a) air resistance = 1050.84N
and the tension, T, in the string, plus the weight of the person, W2 is the answer to (b) The total downward force on the parachute is 1747.2 N.
This, however, is not the right answer...
Any help is really appreciated!
Thanks
Fnet = ma
Forces on Person:
T and W1 known:
Thanks
You've got your plus and minus signs mixed up. The net force must be in the direction of the acceleration. For the person, for example, his weight must be greater than T, in order for him to accelerate downwards.
Thank you!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
