Parity operator and change of variable question
andresordonez
Hi, while reading the section about the parity operator from the QM book by Cohen-Tannoudji (complement F II, page 192), I found this:
Consider an arbitrary vector [tex]|\psi\rangle[/tex] of [tex]\mathcal{E}_\vec{r}[/tex]:
[tex]|\psi\rangle = \int d^3 r \psi(\vec{r})|\vec{r} \rangle[/tex]
If the variable change [tex]\vec{r'}=-\vec{r}[/tex] is performed, [tex]|\psi \rangle[/tex] can be written:
[tex]|\psi \rangle = \int d^3 r' \psi (-\vec{r'}) |-\vec{r'} \rangle[/tex]
But [tex]d^3 r = dx dy dz[/tex] and after the variable change I get [tex]d^3 r' = dx' dy' dz' = - dx dy dz[/tex], so I don't understand what happened to that minus sign. It should be:
[tex]|\psi \rangle = -\int d^3 r' \psi (-\vec{r'}) |-\vec{r'} \rangle[/tex]
right??
Someone told me it had to do something with the meaning of the differential volume, but I'm not sure about that.
Thanks.
The limits on the integral also got swapped. When you change them back around, there's another three factors of -1.
