Rate of Pressure Change with Temperature in Ideal Gas Law
cmajor47
According to the ideal gas law, the pressure, temperature, and volume of a gas are related by PV=kT, where k is a constant. Find the rate of change of pressure (pounds per square inch) with respect to temperature when the temperature is 300^{o}K if the volume is kept fixed at 100 cubic inches.
PV=kT
P=V-1kT
P=100-1kT
\frac{dP}{dT}=100-1k
I don't know how to figure this out. We were given the answer, -.01 psi/^{o}K but I don't know how to get to this with the k there.
k is Boltzmann's constant.
This is weird. You're given information (T=300K) which is not necessary for calculating ∂P/∂T, and not given enough information to figure out what k is.
Moreover, pressure should increase as the gas is heated up. Yet "the answer" is a negative quantity!
Something is definitely not right here.
That's what I thought when I first saw the problem. But where is the number of gas molecules in PV=kT? Either that equation was not written correctly, or k really is just "a constant".
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
